Old 08-06-2011, 12:26 AM   #1
ProStreetDriver
The Real Transporter
ProStreetDriver's Avatar
Send a message via MSN to ProStreetDriver
DIY: Installing A Plug To Repair A Tire Leak (Video)
How to install a plug to repair a puncture/hole in the tread face of a tire. The sidewall cannot be repair as it is unsafe and illegal.
Procedure:
-remove tire from vehicle
-find air leak using soapy water and watch for bubbling
-remove object in tire using a screw driver, pliers, etc
-using the reamer from the tire repair kit, stick in the in the hole so it goes through to the other side, twist reamer to clean hole
-load plug into needle, center plug in needle
-stick plug 2/3 length tire with 1/3 left exposed to the outside
-pull needle straight out quickly without twisting
-cut off access plug using side-cutters, razor, etc
-pump up tire and reinspect for leak
- when all is done, reinstall tire on vehicle
http://www.youtube.com/watch?v=JW6OtOJXtzw
1997 BMW 540i/6 sport
1984 BMW 733i E23: Centra staggered 16" rims, Hartge strut brace, Hartge engine
1994 BMW 740i E32: Sold
ProStreetDriver is offline   Reply With Quote
Old 08-06-2011, 12:04 PM   #2
crxgsr
BMW
plug repairs should really be only used in case of emergencies. The proper way is to use a patch (or plug patch) from the inside.
And also, warranties are void with plugs.
crxgsr is offline   Reply With Quote
