Old 08-05-2011, 10:23 PM   #1
Syn
Question BMW M3 with SMG... is it worth it?
Looking to upgrade from my 330i to 03 BMW M3 [smg gearbox]
Tried to look up online for any feedback but it was mixed up, what do you guys think, is it worth it. is SMG a big expensive headache?
Car just hit 125,xxx km
Thanks for all the feedback
Syn is offline   Reply With Quote
Old 08-06-2011, 11:28 AM   #2
I would personally steer clear of SMG, especially some of the early ones. They are known to have their issues.
There is a thread about a M6 SMG, search for it, lots of good SMG info.
www.enthusiastauto.caContact if you are looking for a car
His--2000 BMW ///M5 .:Jet Black on Black:. Individual - Style 65 Wheels; 9.5" Square Set up;275 Tires;10mm/3mm Spacers; Black Kidneys;Muffler Delete; 3.5" Dual Tips; Beast Power Sway Brackets; "Dinan" Ducts; E60 SSK; BC Coils
Hers--2000 BMW ///M5 .:Avus Blue on Grey/Black:. '01 Exterior Upgrades; E60 SSK
Old 08-06-2011, 11:58 AM   #3
SamE30e
SamE30e's Avatar
It's very.... rough...
If you're driving fast, it's fine. Driving slow and in traffic..Terrible.
91 318is - M50NV (gone)
85 - 325
Old 08-07-2011, 11:14 AM   #4
golf_hero
I had a 2005 M3 with SMG and switched to a 2009 M6 also with 7 speed SMG - night and day difference. I would stay away from early SMG. Super rough and worrisome out of warranty. The SMG on my M6 took some getting used to but as long as you drive it like a manual (auto mode is still rough) it is awesome.
golf_hero is offline   Reply With Quote
Old 08-09-2011, 09:32 AM   #5
JayR_84
Haven't had any issues with any of our SMG cars. I also have manual cars and almost always prefer taking out the M5 instead of the manual M3, especially for highway or track use.
Auto is still king in stop & go.
The early SMG (330i, z4, 5/6 series non-M) and SMG II (m3/m5) cars were all designed using regular manual gearbox. The bellhousing slightly redesigned to house the hydraulic pump, but otherwise exact same internals including gear ratios and flywheel. The gearbox is designed for a human to control it. (the clutch delay valve is removed on SMG cars though). But humans and robots work differently and at different speeds. The issue with M3 (and Z4 / 330i Magnetti-Marelli gearboxes) is that the gear ratios are too far apart and it takes too long for the engine to spin down when changing gears leading to clunky shifts.
The 7-speed M6 SMG III gearbox is a completely different box than what is used in the Manual 6-speed M6. BMW didn't cheap out this time. They made it much smoother by making the gear ratios closer together (by adding a 7th gear) so the engine doesn't need to spin down as much when changing gears leading to smoother shifts, and by adding a lighter weight flywheel which helps with rev-matching, especially when skipping gears.
If you purchase an M3 or Z4/330i there will be delay when changing from 1st to 2nd gear because of the gearing and the computer has to 'wait' for the engine to reach the proper speed before re-engaging the clutch, unless you use a more aggressive shift program then you'll get a 'clunk' from the drivetrain when the engine hooks back up early.
The single most effective upgrade for these SMG's is a lightweight flywheel. It will allow the engine to rev-match much quicker which eliminates the 'clunk' in most cases. Don't go too light otherwise the SMG computer will need reprogramming. Dinan makes some effective lightweight flywheels for both cars and for the M3 has a SMG reprogram map as well. Ensuring the SMG fluid is filled up is important too.
This is also why these cars shift better at higher engine RPM (or faster speeds), the engine load makes it rev down quicker for smoother shifts at higher RPM. The engine revs down slower at slower speeds with less load.
FYI:
M5/M6 ratios
Gear ratios for the seven-speed SMG transmission are
3.99:1 (first)
2.65:1 (second)
1.81:1 (third)
1.39:1 (fourth)
1.16:1 (fifth)
1:1 (sixth)
83:1 (seventh)
3.99:1 (reverse).
The six-speed manual gear ratios are
4.05:1 (first)
2.40:1 (second)
1.58:1 (third)
1.19 (fourth)
1:1 (fifth)
.87:1 (sixth)
3.68:1 (reverse).
The final drive ratio for each transmission is 3.62:1.
JayR_84 is offline   Reply With Quote
Old 08-09-2011, 10:15 AM   #6
3x Beemer
No regrets. I was sceptical of SMG when looking for my M3 but now that I am used to it it's fine. Big learning curve as it is definitely different. Sure nice in stop and go traffic.
As for expense so is an automatic trany when it bites the dust. If you can afford an M3 it should not be a concern. IMHO
03 AW on LSB M3 coupe, BMW motorsport 4.10 Diff, AA Exhaust, OEM CSL rims, Aero Res, TMS subframe, powerflex bshgs, Macht Schnell, Vorsteiner diffuser, TMS steel lines etc..
Complete Comp Pkg Upgrade
98 328is hamann HM2,3.23 diff, ZKW headlights, HID fogs, M3 front, sides, rear and mirrors.UUC rsc36 exhaust, fk coilovers, X brace,UUC tran mounts. Spal fan, Mishimoto rad, AKG rtab, Pweflex CAB. Rogue RSM,SS clutch line, m3 subframe plates, pf bushs
09 F250, 2012 Honda CRV winterbeater
3x Beemer is offline   Reply With Quote
Old 08-09-2011, 11:53 PM   #7
golf_hero
Great info - Thanks JayR
FYI:
M5/M6 ratios
3.99:1 (first)
2.65:1 (second)
1.81:1 (third)
1.39:1 (fourth)
1.16:1 (fifth)
1:1 (sixth)
83:1 (seventh)
3.99:1 (reverse).
4.05:1 (first)
2.40:1 (second)
1.58:1 (third)
1.19 (fourth)
1:1 (fifth)
.87:1 (sixth)
3.68:1 (reverse).
Old 08-10-2011, 04:26 AM   #8
rendered
Took me a good month to get used to it, but I loved my E46 M3 SMG transmission... no problems, and shifted so crisply and quickly in my car... others I drove weren't as good.. but every car is different... drive this car in particular, and see if you like it... keeping in mind it will take you a little while to really appreciate it...
use the highest mode, and maybe even turn traction off, and have some FUN... tell us you don't like it then...
I notice a lot less chatter from the clutch and flywheel with SMG compared to my 6spd Manual E46, and other 6spd M3's.
rendered is online now   Reply With Quote
Old 08-10-2011, 10:06 AM   #9
chromius
chromius's Avatar
When I was searching for my M3, I was in the same boat, wasn't sure if I should even bother looking at SMG M3's or not, then I stumbled across this review of the M3's SMG transmission and was sold.
http://www.bimmerfest.com/forums/showthread.php?t=10057
Basically after reading this review I didn't have any problems looking at either SMG or 6sp Manual. In the end I ended up going with a manual, but if the right SMG had come up, I would have done it.
From what I've read when I was looking, the most expensive problem with the SMG's is if the SMG pump goes out, which does happen, but seems to be hit or miss, and cheaper alternatives to the dealer do exist. Seems like a lot of times the problems are relays or actuators though which tend to be cheaper. The way I looked at it, was that just like anything with a used car, you could end up with an expensive repair regardless of what it is, it's always a risk even if you do your research. So if you're willing to do it, who knows, you could have 200,000k of problem free SMG.
Personally, if the right one comes up with SMG, I wouldn't let that sway you to not get it. It's a used, high strung car, there are going to be repairs. Fix them when they happen, and move on. If the problems start to happen more often than you are able to enjoy the car, sell it and start fresh.
Old 08-10-2011, 10:28 AM   #10
NOTORIOUS VR
NOTORIOUS VR's Avatar
I drove my buddies E46 M3 SMG and it was great! You learn to drive it smooth in any setting just like you do when you get used to any of your cars... There is a way around everything.
E36 · VEMS · TUNING
Google Talk: NOTORIOUS VR
Old 08-10-2011, 03:39 PM   #11
SiR
Vtec just kicked in
manual box pls..even in the worst traffic
-||Old Crayons||-
Old 08-11-2011, 12:59 PM   #12
JUICY J CAN'T
propr'one's Avatar
Before i bought the roadie i was thinking about e46 m3 vert, and i had decided against SMG when i found out the pump failure was somewhat common, and cost 4-5K to fix.
hid headlights
Old 08-13-2011, 05:23 PM   #13
ac_2007
Cruising in Top Gear
ac_2007's Avatar
No SMG and miles are kind of high.
ac_2007 is online now   Reply With Quote
Old 08-13-2011, 07:14 PM   #14
twboy1999
will be hard to e46 m3 under 100k
125km is alrite
MM6 Mesh Wheel / AP Coilover Suspension Kit / Federal 595EVO tires / ///M3AN ONE Black Ceramic Coated Header / Hightech cats / Hightec x-pipe / DTM muffler / D2 Racing Sports BBK / rust paint
Coming soon: 3m di-noc cf wrap airbox
twboy1999 is online now   Reply With Quote
Old 08-13-2011, 11:07 PM   #15
ac_2007
ac_2007's Avatar
Ok, I forgot Im coming from a US website where they use Miles lol. Yes 125k is perfectly fine. I would still opt for the 6 speed manual gearbox though.
