Old 08-04-2011, 11:50 PM   #1
One brake light is out...
It's NOT THE BULB. I already replaced that. I replaced fuses 6, 22 and 23, which are associated with the brake lights.
I pulled the brake light controller in the trunk and looked at that. Seems fine.
Is there a relay or something somewhere else that could be causing this?
Old 08-05-2011, 12:42 AM   #2
Blackedout95
Is the light still making a solid connection when plugged in... or maybe a wire issue.
E46
Old 08-05-2011, 01:11 AM   #3
El Gato Liso
El Gato Liso's Avatar
did you check the bulb? i would obvi check that first.
R.I.P. E30
Old 08-05-2011, 08:23 AM   #4
karmatose
164.3ci Of Fury
karmatose's Avatar
Better yet, is there power getting there? Have you used your dmm to check continuity?
Old 08-05-2011, 08:51 AM   #5
Ceeker
Check continuity as mentioned but also make sure the housing backing which holds the bulbs; it should be mounted securely after replacing the bulb. Sometimes when this isn't seated properly it will give false readings.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 08-05-2011, 10:45 AM   #6
Deetow
+1
I have one mount that's a little finicky and none of the lights worked. Some contact (not the eye kind - the electrical kind) cleaner clears it right up
Deetow is offline   Reply With Quote
Old 08-05-2011, 04:15 PM   #7
I'll check all this later today. The bulb is fine, and that plate is plugged in.
Old 08-07-2011, 01:02 PM   #8
K///Mikes
K///Mikes's Avatar
ive had this problem b4 n it drove me nuts! at first i replaced every bulb! still i had the left brake light and no right driving light. i was like wtf! pulled it off, did some testing, everything was working as it should, next step i figured there must be a loose connection between the back plate where the bulbs mount to the connector itself that u plug into, so i went to part source and baught sum di-electric greese and put a bit on every pin, every bulb. pluigged it back in and voila! they worked! hope this helps
K///Mikes is offline   Reply With Quote
Old 08-07-2011, 03:29 PM   #9
Ceeker
that is one good alternative! and of course helps because it bridges any continuity problems.
Old 08-07-2011, 06:40 PM   #10
I'm going to try that.
I havn't been able to find a voltmeter as I'm not in Ottawa with all my stuff for the summer.
Another thing I noticed is that the brake light warning light is on in the cabin panel. (that thing on the ceiling)
