Old 08-03-2011, 12:40 PM   #1
someguy
Singhy
1998 323is - manual, 158k, two sets of wheels and more [PICS]
Hi everyone,
Unfortunately the time has come for me to sell my favourite car. Some of you may know this as Alex's former car. See here for the original post that he made: http://www.maxbimmer.com/forums/showthread.php?t=127320
Since buying the car, I have only just hit 158,000 km and have done a substantial amount of preventative maintenance and/or upgrades (unless otherwise noted, only OEM parts were used):
Work Done May 10, 2010 @ 146,000 km
-new control arms
-new wishbone bushings+brackets
-new tie rods
-new sway bar links
-new coilovers (Raceland)
-upgraded to Rogue Engineering rear shock mounts + reinforcement plates
-muffler replaced with OEM M3
June 28, 2010 @ 149,500 km:
-new brake discs (solid vented) and long-life/low dust brake pads at all four corners
-swapped stock 2.93 open diff to 3.23 LSD
-swapped clutch with UUC LTW kit:
-clutch disk/pressure plate to M5/M3 OEM
-lightweight flywheel (11.5 lbs)
October 22, 2010 @ 154,950 km:
-replaced clutch slave cylinder
-replaced fuel line (preventative)
-new steering column guibo/coupler
There are also some problem spots:
-there is a small amount of rust on the driver's side rear wheel arch and the bottom of the driver's side door. These were regularly treated with industrial-grade rust inhibitor and have not grown much larger in the year and half that I've had the car.
-The OBC pixels are messed up, which is quite common in these cars
-there is a dead light bulb in the center of the gauges which is noticeable when driving at night, however does not make it difficult to read gauges
-the stereo is wired but not permanently installed into the dashboard due to frequent changes made to the setup (I often test other decks and equipment, and can permanently install it at the buyer's request)
-There is some wear on the driver's seat but no rips or serious wear
-the a/c seems to have a small leak (I refilled it last year but it doesn't blow as cold this year)
I have included all details so that you will not waste time traveling to meet me and be surprised by anything. Please note that the car is located in Oshawa and you would have to meet me there to take a look. The car is wired up with an amp and subwoofer, and that can also be included in the purchase if you'd like. Alternatively, you can drop in your own sub and amp since the car is already wired up for it, or I can remove the wiring. It comes with both summer rims/tires and winter rims/tires. The winters have only been used this past winter and are on 15" bottlecaps. The summers will last you another season or two and are on 16" Style 30 rims.
Also of note, the old clutch/flywheel parts are also available and still have life in them (not sure how much, but there wasn't any slipping).
Asking price is $6500 obo with both sets of wheels, the sub and amp, and certified/e-tested. As stated, this is negotiable based on the final sale conditions.
More pictures are available here
You can message me on here with any questions. I am available weekdays to show the car, preferably in the late afternoon. Hopefully I covered all the bases but if I missed anything important I will be sure to update this thread.
someguy is offline   Reply With Quote
Old 08-05-2011, 11:08 AM   #2
someguy
Singhy
Bump...Price reduced to $5500 obo without sub, amp, and cert/e-test
Edit: stereo is now properly installed.
Old 08-08-2011, 10:35 AM   #3
someguy
Singhy
bump
Old 08-09-2011, 03:04 PM   #4
someguy
Singhy
bump
Old 08-15-2011, 12:35 PM   #5
someguy
Singhy
bump
Old 08-22-2011, 10:13 AM   #6
someguy
Singhy
bump....$5300 takes it.
Old 09-03-2011, 05:41 AM   #7
someguy
Singhy
bump
Old 09-04-2011, 11:04 AM   #8
3x Beemer
how do you like the performance of the clutch/flywheel combo? much different over stock? worth the upgrade?
17 Audi A4 S Line
03 AW on LSB M3 coupe, BMW motorsport 4.10 Diff, AA Exhaust, OEM CSL rims, Aero Res, TMS subframe, powerflex bshgs, Macht Schnell, Vorsteiner diffuser, TMS steel lines etc.. Sold
Complete Comp Pkg Upgrade
2012 Honda CRV winterbeater
3x Beemer is offline   Reply With Quote
Old 09-06-2011, 09:45 PM   #9
NITRO89
Slammed E36
NITRO89's Avatar
is the car still available?
NITRO89 is offline   Reply With Quote
Old 09-08-2011, 08:57 PM   #10
someguy
Singhy
3x beemer: I noticed that the throttle is more responsive and rpms drop faster than with the stock flywheel. the bite on the clutch is better as well, with respect to "feel".
Nitro89: yes, car is still available.
bump
Old 09-16-2011, 04:03 AM   #11
AlexS
AlexS's Avatar
Holy shit!!!!
miss this car. someone buy it before I do.
AlexS is offline   Reply With Quote
Old 09-16-2011, 02:03 PM   #12
someguy
Singhy
Hi Alex!
Bump...car is for $5000 now as is. Need money for school
Old 09-29-2011, 09:38 AM   #13
someguy
Singhy
bump
Old 11-14-2011, 01:23 PM   #14
someguy
Singhy
bump..
