Old 07-28-2011, 10:02 PM   #1
Ceeker
problem with dash lights
so I had a problem with the car holding a charge. On that really hot day the car started in the morning and wouldn't start as the car and the day heated up. I needed to jump start it but took little effort. it did this like clockwork the whole week. Morning she starts when cool and later no start.
I rebuilt the starter; I rebuilt the alt; and changed the bat. now I get this. The 3 lights at the bottom come up when at idle; as I rev the motor upward to 2 grand it fades out and stays out as long as I don't let it return to idle.
sorry bout the large pic.
any ideas or help would be appreciated.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 07-28-2011, 11:12 PM   #2
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
Last time I changed my alternator, those lights came on for a bit upon first startup. Once I got the car's revs up, they went away and stayed away. When you rebuilt your alternator, you changed your voltage reguator? Maybe it's the wrong one? Maybe it's faulty? I don't know, that's just a stab in the dark, but those lights like to come on when the car stalls (or almosts stalls, but keeps running) so I'd think it's related to the alternator more than anything... like the belt not being tight enough, but I'd expect you to know how to change a belt by now.
Grow up and move on.
Old 07-28-2011, 11:17 PM   #3
Ceeker
thanks Scott, it was rebuilt a couple years ago but never used. I suspected it might be the voltage regulator being faulty. so I might change it to see what happens. thanks again; oh and the matching visors is a cool things on the coupe. I don't know if I'd do away with the vert one because I like the plastic folder for the roof instructions. :-)
Old 07-28-2011, 11:28 PM   #4
E30M42cab
E30M42cab's Avatar
Yeah, my vert never came with the instructions for whatever reason. Maybe it did, but was removed after it got all faded and yellow. Anyways, check that regulator and let me know.
Old 07-28-2011, 11:53 PM   #5
Before you just go randomly changing things, why not check the voltage during charge and during load (headlights / rear defogger) and post the results?
Old 07-29-2011, 08:04 AM   #6
Ceeker
I honestly thought about that; but I had a new alt kicking around and 15min later it was in. the starter took a bit longer. lol. both needed changing; they were on there way out after inspecting them. thanks for the input.
Old 07-29-2011, 09:24 AM   #7
Ya makes sense. So, shoot down to Princess Auto or XS Cargo and find a multimeter. Its something that once you have you'll wonder how you go buy without. Get a digital one, but don't spend more than $10. Princess Auto have them on sale all the time for $6.
Then you can really get into the trouble shooting aspect of this before you have to buy any more parts.
Old 07-29-2011, 10:03 AM   #8
Ceeker
the alt was free and the starter cost me 70.00. so it wasn't toooo bad.. :-)
my buddy can bench test my two alts to see if one might need rebuilding. He suspects it's the voltage reg. since there is good connection/power as the batt light goes out. but might not be charging at low rpms. I got one of those meters...talk about lazy on my part...LOL.
Old 07-29-2011, 12:58 PM   #9
BmW1819
put a multimeter on and check to see what your alternator is putting out
Old 07-29-2011, 01:33 PM   #10
Ceeker
red lead goes on the + ? black goes on the body of the alt or the ground -?
I guess I set the meter to volts?
Old 07-29-2011, 02:03 PM   #11
karmatose
164.3ci Of Fury
karmatose's Avatar
DMM 101:
Go to V on the dial. 200 should do it as you want to see two digits and a decimal place.
Put the red lead on what you want to test (obviously) and the black lead to the body.
Old 07-29-2011, 09:01 PM   #12
Ceeker
Originally Posted by karmatose View Post
DMM 101:
will do! thank you belly belly much!! :-)
Old 07-29-2011, 10:46 PM   #13
karmatose
164.3ci Of Fury
karmatose's Avatar
If you DON'T get a reading, try a different spot on the body for ground before giving up on it. If you're looking at stuff under the hood at the fuse box, use one of the bolts on the shock tower. The shock tower itself won't give you the ground you need.
Old 07-29-2011, 11:08 PM   #14
Ceeker
There are a couple of things I am going to also look over. 1) wear on the belt. 2) the v- pulley on the rebuilt is slightly larger outside diameter and deeper groove. So I wonder if the belt is sitting snug in the channel? Also might tighten it some more to see if that changes anything. I did tighten it but! maybe the belt is tired.. I did drive the car tonight for about 30min on the highway to see if I am draining the battery and it apparently isn't. So I think it is charging.
thanks again for your help.
Tomorrow is another day!
Old 07-30-2011, 12:57 AM   #15
BmW1819
first thing first is the alternator charging???? cause i no some cars when first started all lights are on till u rev to like 1000 rpms, than lights stay out. So check to see if it's charging put it on the battery terminals when the car is running
