Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 07-26-2011, 10:07 PM   #1
bayerish 325
Best tire pressure gauge
Hi,
I have 3 tire pressure gauges giving three different (and obviously very inaccurate) readings.
What is the best tire pressure gauge out there? Are the ones on sale at Canadian Tire for under $20 good and accurate?
I am looking for something very accurate and reliable.
Thanks for your input.
bayerish 325 is offline   Reply With Quote
Old 07-27-2011, 12:24 PM   #2
crxgsr
BMW
pressure fluctuates with the temperature and weather. Also altitude plays a role as well.
Generally, accuracy isn't the most important thing, As long as the two fronts are the same and rear two are the same. (and the pressures are somewhat close to specs).
You can go with a digital gauge if you want more accuracy.
crxgsr is offline   Reply With Quote
Old 07-27-2011, 12:47 PM   #3
I find this style to be the most accurate:
But i agree with crxgsr, if its off by 1-2 PSI its not a big deal, as it will be evenly off by the same amount for each tire.
Old 07-27-2011, 12:50 PM   #4
pawcio
pawcio's Avatar
i'm pretty sure that none of those cheap store bought tire pressure gauges are properly calibrated. in which case its hard to say which one gives the most accurate reading. therefore i have to agree with consistency vs accuracy statement as long as its not too much out of whack. being digital doesn't mean its properly calibrated...pencil, dial and digital gauges can be equally good or bad.
__
Old 07-27-2011, 11:20 PM   #5
bayerish 325
Thanks for your input. It is true that weather conditions, altitude, temperature etc... are to take into consideration. It makes sense to go for consistency between tires fronts and rears (since it seems unfortunately impossible to get accuracy). But, how can I can I know if I am even close to specs when 5 (yes 5) gauges are off 4 to 7 PSI???
The BMW owner manual is quite specific about which tire pressures should be used according to different speeds and number of passengers.
Old 07-28-2011, 08:18 AM   #6
pawcio
pawcio's Avatar
spend a small fortune http://www.omega.com/ppt/pptsc.asp?ref=DPG4000-KIT
this thing even compensates for temperature.
__
Old 07-28-2011, 09:41 PM   #7
Robb
EX E30 M3 Owner
Robb's Avatar
If anyone is looking for a good/accurate tire guage, I bought this one from this place.
I thought Id post here, since I think it seems like a quality product at a fair price.
ACCUGAGE PROFESSIONAL TIRE GAUGE from Aircraft Spruce
This very accurate bourdon tube tire gauge offers precision pressure control and a rugged steel case with rubber shock-absorbing cover. It comes complete with a 12" long flexible braided hose, a bleeder valve, and stop hand. It is easy to read the pressure on this 2" gauge with 1" psi markings and 60 lb. range. Excellent for use on aircraft tires as well as cars and trucks.
Robb is offline   Reply With Quote
Old 07-28-2011, 11:14 PM   #8
bayerish 325
Many thanks. Definitely looks like a great product and at a very fair price! I will order one.
Old 07-29-2011, 01:54 AM   #9
noodles101
ΛΦΕ
noodles101's Avatar
when i used to work in a shop. all the mechenics used the rounded dial ones.
the ones that are ONLY for checking pressure, NOT the ones where you can check pressure and add pressure at the same time.
i personally use ..the canadian tire 'pen' style ones..lol i think its good enough.
Old 10-08-2012, 10:33 PM   #10
Killerbimmer
i find of all the tire guages out there and i have bought a lot. The old fashioned pencil guage usually lasts the longest and i find is the most accurate
Killerbimmer is offline   Reply With Quote
