Old 03-05-2002, 12:17 AM   #1
M3ti Compact
Fuel Efficient 318 Member
M3ti Compact's Avatar
What's the difference between 95 and 96 ti?
I was looking over a few well-known BMW tuner sites...one thing I kept on noticing is that most parts offered for the ti compact model are for 1996 and up (eg. Dinan and Hartge)
I have a 1995 ti...the only difference between 95 and 96+ I thought was a new grill design and a slightly bored out version of the 1.8L inline-4
Other than that, shouldn't parts offered for a 96 fit a 95?
Another thing...would Z3 suspension parts fit the ti? I heard about this from someone...but never gave it too much thought...
Old 03-05-2002, 02:11 AM   #2
Bliss
Administrator
These are the specs for the 96' so you can compare to what you have in your 95'. As in looks wise though i don't think much other than the grille?? maybe? Well here they are.
1996 Technical Specifications
318ti
MSRP $20,560 (base car)
General 318ti 3-Door Coupe
Curb weight, lb.:
......Manual transmission 2745
......Automatic transmission 2833
Weight distribution (manual transmission), front/rear, % 53.4/46.6
Wheelbase, in. 106.3
Track, front/rear, in. 55.4/55.6
Length x width x height, in. 165.7 x 66.9 x 54.8
Body 318ti 3-Door Coupe
Type Unitized all-steel structure
Aerodynamic drag coefficient 0.35
EPA size classification Compact
Accommodations 318ti 3-Door Coupe
Seating capacity, persons 5
Shoulder room, front/rear, in. 54.0/53.1
Head room, front/rear, in. (37.7/36.4 with optional sunroof) 38.7/37.0
Leg room, front/rear, in. 41.1/32.6
EPA interior volume, cu ft. 87.0
EPA cargo volume, cu ft. (maximum cargo space) 15.0
Engine 318ti 3-Door Coupe
Engine type DOHC 16-valve inline 4-cylinder
Bore x stroke, in./mm 3.35 x 3.29/85.0 x 83.5
Displacement, cu in./cc 116/1895
Compression ratio 10.0:1
Power @ rpm, hp 138 @ 6000
Torque @ rpm, lb-ft. 133 @ 4300
Engine-management system Bosch HFM-Motronic 5.2 with knock control (2 sensors)
Fuel requirement Premium unleaded
Fuel capacity, U.S. gal. 13.7
Drivetrain 318ti 3-Door Coupe
Drive system Front engine/rear-wheel drive
Manual transmission Getrag Type B, 5-speed
Ratios:
......1st 4.23:1
......2nd 2.52:1
......3rd 1.66:1
......4th 1.22:1
......5th 1.00:1
......Reverse 4.04:1
Final drive ratio 3.45:1
Automatic transmission THM R1, 4-speed
Ratios:
......1st 2.86:1
......2nd 1.62:1
......3rd 1.00:1
......4th 0.72:1
......Reverse 2.00:1
Final drive ratio 4.44:1
Chassis 318ti 3-Door Coupe
Front suspension Struts, arc-shaped lower arms, coil springs, twin-tube gas-pressure shock absorbers, anti-roll bar (with Sports Package - sports suspension calibration)
Rear suspension Semi-trailing arms, coil springs, twin-tube gas-pressure shock absorbers, anti-roll bar (with Sports Package - sports suspension calibration)
Steering type Rack & pinion, engine-speed-sensitive variable power assist
......Overall ratio 15.4:1
......Turns, lock-to-lock 3.4
......Turning circle, ft. 34.1
Wheels:
......Standard Steel, 15 x 6.0J
......Optional Cast alloy, 15 x 7.0J or 16 x 7.0J
Tires:
......Standard 185/65R-15 88T
......Optional 205/60R-15 91H or 225/50ZR-16
Brake system 11.3-in. discs front, 10.7-in. discs rear; vacuum assist
Antilock braking system (ABS) Standard
Performance data 318ti 3-Door Coupe
Acceleration, 0-60 mph, sec., manufacturer's data,man./auto. 9.3/10.3
......Car and Driver 8.3
......Road & Track 8.6
......Motor Trend 8.9
Top speed, mph, manual/automatic 116/116
Fuel economy, EPA estimated mpg, city/highway:
......Manual transmission 23/31
......Automatic transmission 23/31
For maXbimmer decals, please email info@maxbimmer.com
Old 03-05-2002, 10:57 AM   #3
KIRASIR
Your Nightmare
KIRASIR's Avatar
well...there are a couple of differences.
1) The grills are the same. Kidneys were changed in 97.
2) Your car has M42 1.8l engine with OBD-I. 96+ have M44 engine with OBD-II. This is the major difference.
3) There are also small trim differences. 98+ came with vented front rotors. 95 is the only year you could get a limited edition Club Sport ti. I believe LSD was not availabe after 95 since it was replaced by traction control.
The front of the ti is the same as a 4dr up to the A pillar. The rear suspension is the same as e30 one. Rear suspension parts between z3 and e36/5 should be interchangable as well.
SL
Old 03-05-2002, 05:09 PM   #4
djcontra
Gets Blown Daily
djcontra's Avatar
wow this makes the Ti sound like a bmw frankenstein creation
Mods
-Shortstack headers
-Vortech RRFPR
-255LPH Walbro fuel pump
-Keskin KT1 17x8.5 & 17x10
-Remus full catback
-SMT6 EMS (Untuned)
Old 03-05-2002, 05:22 PM   #5
KIRASIR
Your Nightmare
KIRASIR's Avatar
I think it got the best of both worlds.
Old 03-05-2002, 05:27 PM   #6
djcontra
Gets Blown Daily
djcontra's Avatar
sounds like it
i wouldn't mind owning a Ti with a serious engine implant
something crazy like a bmw 12cyl =)
i've seen a z3 roadster with a 12cyl, so why not the ti =)
Mods
-Shortstack headers
-Vortech RRFPR
-Remus full catback
-SMT6 EMS (Untuned)
Old 03-05-2002, 09:32 PM   #7
M3ti Compact
SL
COOL! I have OBD-I! I heard lots of people that have OBD-II with aftermarket mods cause their ECU have a heart attack...they all want OBD-I! Hehehe!
I do have the Sport package on my ti, dont think it's a Club LTD however...
LSD came standard with Sport package...excellent for hard driving.
Thanks for all your help!
pic...I SWEAR I have rims in the garage...those are just my SNOW TIRES!!!
cut and paste
www. geocities.com/MotorCity/Lane/6262/318.jpg
Old 03-06-2002, 12:45 AM   #8
KIRASIR
Your Nightmare
KIRASIR's Avatar
It's been done before by Racing Dynamics. Search the net.
SL
Originally posted by djcontra
sounds like it
Old 03-06-2002, 01:00 AM   #9
KIRASIR
Your Nightmare
KIRASIR's Avatar
Sorry to spoil your joy but if that white ti is yours then
1) It does NOT have Sports package. It looks like an Active.
2) It may have an LSD but I doubt it.
Here are a couple of pictures of a Sport ti.
http://www.happytogether.com/318ti/g...our/index.html
SL
cut and paste
Old 03-06-2002, 04:56 PM   #10
M3ti Compact
You must be kidding me!
I purchased it new from the dealer and paid like 4 grand extra for a sport package...
Those are not the original rims that came with on my car...they are my ugly snow tires...it looks much, much better with the rims on...i'll take a pic once the snow goes away.
I noticed that newer versions of the TI came with M front spoiler and side skirts and M badging...which mine didn't have...
I got it right in 95...one of the first few batches to come out in Canada.
Or maybe the Canadian version is quieted down a little bit from the version in the pictures you posted...looks like a US version with the 5-spoke rims and body kit.
What I got with the sport package was
1) M Technic lowering springs
2) Fog Lights
3) Rear window wiper
4) LSD w/ 25% lockup
5) Heated mirrors, and windshield washer jets
6) Half leather and cloth 10 way sport seats
7) 205/60R 15 on unique to Ti Sport 10 spoke rims
8) Sunroof
There are no discrepancies between my car and what I was told was gonna be added...
I know it's not an active because I don't have cruise control, full leather interior or the Unique Ti Active rims.
I know it's not a base because I have all the stuff that the Sport has and base models don't come with fog lights...
Old 03-06-2002, 05:13 PM   #11
M3ti Compact
1995 318ti Factory Options
Automatic Option on all models
Air Conditioning STD on Active, option on base and Sport
LSD (25%) STD on Sport, option on active and base
Heated seats Option on Active and Sport, N/A on base
Premium Sound Option on Active and Sport, N/A on base
Cruise Control STD on Active, option on sport, N/A on base
Metallic Paint Option on all models
Montana Leather Option on Active and sport, N/A on base
Front Armrest Option on Active and sport, N/A on base
On-board computer Option on Active and sport, N/A on base
Sport package includes
All base standard features inlcuding
M-Technic lowering springs
LSD (25%)
205/60R 15 on unique ti Sport rims
Fog Lights
Heated exterior mirrors
Heated windshild washer jets
Rear window wiper
10 way adjustable front sport seats with unique leather/cloth
Sunroof
Active package includes
All base standard features including
205/60R 15 on unique ti Activ rims
Heated external mirrors
Rear window wiper
Fog lights
Cruise control
Sunroof
A/C
Both packages cost exactly the same.
Old 03-07-2002, 10:42 AM   #12
KIRASIR
Your Nightmare
KIRASIR's Avatar
My bad. I just checked.Sport package for 95 indeed did not have m-technik. Only Club Sport did. 96+ all Sports have m-technik body panels.
