Old 06-28-2011, 10:44 PM   #1
Dado 540
Dado 540's Avatar
Anyone dealt with an E39 540i auxiliary water pump
I have developed a leak on mine. Prices seem to be in the $400s for a replacement part.
E39 540i Sport
Old 06-28-2011, 10:52 PM   #2
simplycars
simplycars's Avatar
yes, it happens often on 7s and 5s.
whatever you do don't buy used part.
simplycars is offline   Reply With Quote
Old 06-28-2011, 11:05 PM   #3
Nick_V
Nick_V's Avatar
Not sure if it's set up the same as on an E34, but if so you can just bypass it.
Old 06-29-2011, 12:13 AM   #4
It depends what year. They have 2 types. Never seen a problem with the old type, altho the VALVES tend to go...but pump i have seen in the high 300K, all worked and no leaks. Chances are a good used one will outlast your engine!
Old 06-29-2011, 04:34 PM   #5
MLue1
MLue1's Avatar
Hey Dado, mine had a leak but it stopped as misteriously as it started. My E38 740 buddy David fixed his auxiliary water pump and if has been good for a coupke of years now. His instructions were simple, take apart the auxiliary water pump and reseal by applying RTV to the mating surfaces, put part back togeather but do not tighten the bolts all the way, wait as per RTV instructions for the sealant to setup, then tighten to spec.
Try it what do you have to loose.
Mark
'99 E39 540iT
