06-22-2011, 04:58 PM
#16
Car: 91 318i, 96 328ti
Originally Posted by 325isdan
Rather send 2K on an OEM MTech II kit.
and not paint? I'm sure it will look nice on a rusty and with damaged paint car!
06-22-2011, 10:17 PM
#17
pod stromom
Car: 325is 328is
lol
06-22-2011, 10:27 PM
#18
ΛΦΕ
Car: 330ci , 328is
how bad is the rust? u might be able to find same body colour pannels and install them...and give it a professional level wet sanding / buff job ... will be ALOT less then 4.5 k...
06-22-2011, 10:30 PM
#19
ΛΦΕ
Car: 330ci , 328is
and if the rust of really bad , get body work done / paint the pannel.
and finish off with a buff job to blend in the fresh paint / old paint.
06-23-2011, 08:31 AM
#20
Car: 89 325izle - 95 318i
Where these cars rust out I am sure the kit will cover it. Then you paint later down the road. No point in painting a car then getting a body kit after.
E30's just look 100x better with Mtech II.
06-23-2011, 09:39 AM
#21
12 Years with the E30
Car: 325i 1987
Jesus guys try to check your grammar I'm getting a headache trying to decipher some of this.
Go buy good paint, it doesn't need to be the best paint. Do as much of the prep as possible. You should be able to get a starving (reasonably skilled) person to spray it. I'd think that getting a decent job with good paint is possible for under 1.5k
06-23-2011, 04:47 PM
#22
I agree e30's look real nice with the mtech II kit, but only when it's installed properly and the car is painted properly. Otherwise it will just look like something my dog produces every morning with a cocktail umbrella stuck into it!
06-23-2011, 08:36 PM
#23
IH8BART
Car: 1987 325is
If I would have known I would have tried to find them in the same colour but I think the fenders would have been a tough find. I have some nice doors and fenders but they are red and blue.
1987 325is
06-23-2011, 08:40 PM
#24
IH8BART
Car: 1987 325is
I think I will paint the inside of the doors and fenders myself, mount them and do as much as I can and get someone to spray it. I have a couple of numbers of guys who do it on the side, I just haven't had time to see them. 1.5K would be nice.
1987 325is
06-24-2011, 09:04 AM
#25
Car: e30 touring
Send me your number, I have a neighbour that does it (river canard area/amherstburg) on the side as a hobby, and a friend in Lasalle with a shop. What color are you looking at?
What's the rust like? Is it full cut and weld or just surface rust that hasn't eaten through that can be ground down and sealed?
Jeff
06-24-2011, 10:54 AM
#26
IH8BART
Car: 1987 325is
Jeff
You have been PM'd
1987 325is
06-25-2011, 08:29 AM
#27
Car: Many
Originally Posted by BMW BMXer
When I got my e30 repainted I went through a similar situation. 3400 - 5000 quotes that sent my head spinning as a dishwasher at the time.
I was eventually able to find a shop willing to do the job for 2000 and while it wasn't perfect it was very livable and it held up quite well (and is still doing so as far as I know).
Based on that experience I would never pay less than $1500 for a full respray. The problem with paint is that you get one chance to be satisfied and if you cheap out and it's not done to your expectations you are boned.
If there is any rust repair I would not cheap out because no matter the paint quality if the rust undermines it whats the point.
I have the car Dave is talking about. The paint is a little thin and chips easily but for $2000 it was worth it and it has held up decent and still looks okay. I bet half of that cost was just in the prep.
If you want to save a ton of cash strip all the trim down yourself and remove lights, door handles everything in their lot. Put everything back together as well. A lot of the cost is in the disassembly and reassembly of all the parts.
If you want to go really cheap just to look halfway decent for 3 years or so, find yourself a Maaco or similar place near the airport (carlingview) there used to be a place advertised off the highway for a $500 spray.
... oh ya... don't bother trying to find a cheap place to spray and try to change colours.
Cam G.
85 325e M5
07 Honda Shadow Spirit 750
06-26-2011, 11:06 AM
#28
Car: none
Decent paint is expensive! Canada has switched to waterborne paint since last summer, and it costs even more than the solvent paint (solvent paint is already phased out, no longer sold).
Here is a summarized list of what you will need:
>A gallon of Waterbone basecoat. Sikkens and PPG are ahead of other companies in the waterbone game. A gallon of Sikkens basecoat starts from at least $500. It costs even more for metallic paints and red shades.
>Reducer for basecoat
>Clearcoat + hardener- At least $200-$300 for a decent clear. If you want the best, you can easily spend at least $400.
>Epoxy primer kit- from $200 (ok brand)
>2k urethane primer kit- from $150 (ok brand)
>Various surface cleaners, wax and grease remover, waterbased cleaner, etc...
Not to mention different guns for primers and topcoats, sandpaper, tack clothes, masking tapes and papers, blower guns for water paint, ...
It all adds up quick. Bodywork is labor intensive, lots of sanding, masking, many steps involved, would take days...
06-26-2011, 11:28 AM
#29
hates chrome
Car: 330i
06-26-2011, 08:22 PM
#30
Car: '89 325is
Originally Posted by fitter527
First off, come check my car out at a meet...I painted it all with Tremclad rattle cans and am in the process of wet sanding and buffing...
As for having it done properly, my advice would be to get it done right and pay the money, or, do as much of it yourself, ie-sand and tape it, then have it towed and sprayed as cheaply as possible. No point paying over $1K for a crappy job, you're better off paying $500 for a crappy job...
The guys that are charging $4K will think that any work done by anyone else but them will look like garbage and try to scare you into thinking you will ruin your car if you go anywhere else, but the fact is, maybe 5-10% of the entire population will actually notice a less expensive paint job, and even then, they'll probably have to be within 10 feet of your car, looking for flaws.
Someone else asked earlier if you are going to put your car in shows? I think that's the question you need to answer. If so, get it done right and get the perfect job and pay a bit more. If not, do it cheaper and spend the money on other parts of the car to make it more fun to drive, because most everyone else will see a shiny car that's all the same colour.
Finally, can I also say that most of the paint and body people I spoke with were extremely negative, arrogant and rude? These guys make engineers seem humble and and approachable. When you try to get a deal, they treat you as though you are an absolute piece of crap, and lord help you if you do anything yourself, they won't even touch your car...I almost had to punch out about 3 of them based on attitude alone. Then again, I'd proabably have an attitude if I was charging people $4K for something that they could do themselves for $100 and have it at least look functional. It's painting a car, not repainting the sistine chapel, for God's sake...Everything they told me that would go wrong if I did it myself didn't happen...thanks for trying to take advantage of someone new by using scare tactics and BS, A$$holes
From Eyesore to Heat Score
