Old 06-22-2011, 11:04 AM   #31
Originally Posted by Renboy View Post
I think you misunderstood what I was trying to say. I fully support people maintaining their cars, and even spending obsurd amounts, but only when needed. I see no reason why someone would spend $2500 on a suspension for a car worth $9k, when $600 will fit their needs perfectly. The rest is a waste and could be used on other things.
By mentioning the cost of the car in your argument you are contradicting yourself. It's like you're trying to say that spending a lot of money on suspension is fine, but only if your car is expensive, if you have a cheap car you should only use cheap suspension. So those guys out there with their $2500 E30 track/auto-x cars running AST 4100 coilovers worth $2500 must be idiots? What's a beat up, rusting E30 worth these days? $1500? Heck I must be retarded because I've spent more than that upgrading the suspension on my car.
I agree with you when you say buy something that fits your needs, but be realistic about it. If you've only got $400 to spend and you want to go low that doesn't mean you should buy the cheapest coilovers you can find because that’s all you can afford. Do some research, figure out what’s tried, tested, reliable, and will fit your budget then start saving your pennies.
Old 06-22-2011, 01:43 PM   #32
Renboy
Normally I would agree with you, and had thought of leaving the price out as I was typing. But, I included it strictly because there is a very strong correlation between the price of a car and the cost of aftermarket upgraded parts for it. A turbo kit for a civic is $5g's, for an e9x m3, $20g's. Not to mention, in every post in this thread other than the last one I pointed out that I was talking only about a daily driver that wouldn't see track time. A track car will always need something different. Not to mention, I did recommend he not get coils and even offered up an alternate suggestion that's in a similar price range, but has a solid reputation and would probably fit his needs better.
What I was trying to point out was that buying track quality/oriented parts are wasted when installed on a daily street car. It makes as much sense as installing solid mounts in the same car. They're expensive, and great at the track, so they therefore must be the only option.
Old 06-22-2011, 01:51 PM   #33
Renboy
I forgot, I was also trying to point out that just because something isn't expensive doesn't automatically mean it's crap. There's a member selling ssk's on this forum for about $75 and everyone is pleased with them, yet the uuc ssk is $400....how can that be?
Old 06-22-2011, 04:18 PM   #34
There is a measurable difference in quality and performance between those two products. Not to make up the full difference, but still.
Old 06-22-2011, 04:51 PM   #35
Renboy
At more than 5x the price I would hope so. I was just proving you don't have to spend a fortune and be happy with a product.
Old 06-22-2011, 08:35 PM   #36
I don't agree... Sure people may be happy with the product, but that still doesn't mean its right or it is doing its job properly. It is pure ignorance that leads these people along. SSK or suspension... its all the same.
Old 06-22-2011, 10:09 PM   #37
Renboy
Please tell me you're joking. The BMW performance shifter is only about $100+/-. If anyone should know how to do the job properly, it would be BMW. So, you think UUC's shifter is worth 4x as much as the BMW shifter? And is doing the job 4x better?
Sorry to burst your bubble, but it's a shifter....a glorified rod with a pivot ball. If anyone is ignorant, it's people like you, that soak up the UUC marketing where your shifter has to have balls of steel (which incidentally even $30 ebay shifters have them made of brass). The pivot ball, doesn't wear out. They just try to differentiate themselves somehow so they can come close to justifying their idiotic markup.
As for the suspension, so you're saying that unless a car has a 4-way adjustable coilover, with camber plates, remote resevoires and edc then they're not doing the job properly? Because that's a $10,000 suspension.
Old 06-30-2011, 02:32 PM   #38
Adrian_Lindn
Adrian_Lindn's Avatar
Installed over the weekend boys! handling is awesome. Me and my buddy installed on sat/sun took a while....But its done and im happy! had to adjust many times to get the height right but it looks perfect now....I will post pics soon! juust wanna take ones with a camera not a black berry.
Adrian_Lindn is offline   Reply With Quote
Old 06-30-2011, 02:38 PM   #39
doogee
doogee's Avatar
You sir are ignorant. I suggest you do some reading on the UUC EVO3 to understand why it's expensive. It's completely different from a BMW shifter in every way. It doesn't mount in the stock carrier spot, is height adjustable, solid (no rubber) and has bearings instead of bushings for the selector rod. Is it worth the extra money? I think so.
Hahaha, no one seems to know what handling even means
Dakar M3 Track Build Thread
Old 06-30-2011, 02:40 PM   #40
Adrian_Lindn
Lol Im not a track driver! read uup....I can take corners better than i used to...Is that better mr professional race car driver?
Old 07-07-2011, 08:29 AM   #41
Adrian_Lindn
So I have these coil overs installed. Everything was going great…Then once I took them on a long trip to Bancroft and drove for a week I realized the springs have now been worked in and settled. Once this happened, the front is pretty low and for some reason on every single turn im hearing a noise as if the spring is making the noise. I know it’s not the sway bar link since I did buy a shorter one from and Impala. Any ideas on what could be happening? I’m going to jack it up tomorrow and take a look but has anyone every experienced this problem? Not a rubbing sound but a sound coming from the coil its weird?
Old 07-07-2011, 08:45 AM   #42
lol, you eventually hear this from all raceland/rokkor owners. Some just take longer to admit it.
Learn your lesson yet?
Old 07-07-2011, 08:48 AM   #43
Adrian_Lindn
Lol My buddy had them on his and it wasn’t the case on every turn….it has to be something?
Old 07-07-2011, 10:23 AM   #44
It could be a shitty upper mount that's binding and it causes the spring to rotate relative to the strut. It will bind a bit then pop.
Old 07-07-2011, 10:30 AM   #45
Adrian_Lindn
Can this cause damage? is there anything i can do?
