Old 06-09-2011, 05:01 PM   #1
automadness
2001 330 ci weather stripping
hi i have a 2001 330 ci 2 dr the weather stripping on both doors came apart on tuesday with the hot weather did this happen to anyone else what do you recomend to fix it polyurethane ?
automadness is offline   Reply With Quote
Old 06-10-2011, 02:49 AM   #2
mercforhire
Use these yellow strong glue, put in the trim, glue it back to the door frame and hold it in place with many tapes. Keep it for 2 days, then remove the tape.
mercforhire is offline   Reply With Quote
Old 06-10-2011, 03:01 AM   #3
Fixing it never lasts very long...Replacing is the real solution, not very cheap, but it works! I should have a good pair if needed....
Old 06-10-2011, 08:59 AM   #4
jabela
I used the good 3M very glue years ago and it hasn't failed. However it has started to crack from age. What price can you do for the driver's side stripping?
www.maisonapothecare.ca
Old 06-10-2011, 12:56 PM   #5
Wrong.
Right
http://www.shop3m.com/60455029946.ht...strip-Adhesive
Used this 3M weather striping adhesive glue on my E46 and a few other friend's/family member's cars as well. Once I used this it hasn't failed. Mine has been going strong for 3 summers.
Old 06-10-2011, 03:29 PM   #6
^^^only if you are cheap and want your car held together with glue! In that case zip ties are good intercooler mounts too! lol
Old 06-10-2011, 03:55 PM   #7
mercforhire
It's not like there is a BWM glue.
I posted a thread about a pair of headlights for $250 I bought from you that was badly removed from a junked car and had its wiring completely butchered, I sold it for junk value at a major loss afterwards.
Shouldn't be calling people cheap for not buying overpriced used stuff from you.
Old 06-10-2011, 09:55 PM   #8
Reusing a stronger glue to old together an OEM piece that was held by lesser grade adhesive is a totally different story than holding an intercooler with zip ties. By that logic, why not replace the whole motor when you get a valve cover gasket failure, or a pulley breaks? Afterall, that is the "baller" solution.
And if you search online, you will see the OEM glue is not a permanent solution. They fail time and again. What is the point of shelling out big dollars on such a stupid item & replacing it only to have it come off again? The 3M adhesive solution has proven to be better than the OEM replacements.
PS. You reeeeally ought not to talk about others being cheap with their cars
Old 06-11-2011, 12:56 AM   #9
Why not!?? I'm cheap as hell!!! I got my 330 for $1000, was FREE by the time i sold the stock rims and a few other bits, paint job was $250, and i can make a list of others...So at the end i like my car the way it is, i can spend my $$$ at more mods (and other toys)
Old 06-11-2011, 01:10 AM   #10
Dont even start whith this! I told you before you got them they are aftermarket and a few tabs ARE broken,even told you how to fix it. The wiring was just unpluged, the only thing that needed to be cut was the angel eyes, that were hooked to the car harness (so could NOT be separated!). I sell OEM headlights for $400 each, so at $250/pair it is what it is!!! I told you everything i can about them, even gave you a discount because you got a few things. If you couldnt get them figured out, not much i can do.
Old 06-17-2011, 12:27 AM   #11
mercforhire
What you sold me was not OEM nor cheap, I was ignorant at the time and paid $250 for a pair of used lights. Which I later found out they only cost $209.98 brand new.
http://www.migicute.com/hdbk46299by.html
Plus I paid $150 for a pair of expensive rear corners. The discount I got was just a cup holder.
I paid you straight away without any lowballing or other annoying cheap sh1t.
Later, I was frustrated when I tried to install them and I even posted a thread some pics of the fubar of a mess removal job you did. In the end, I just sold it for cheap for parts value. I did not complain about any of this, I didn't know better so I took it as a lesson.
You have my money, at least be a little helpful and show some respect to your customers.
Old 06-17-2011, 12:29 AM   #12
mercforhire
Plus I paid $150 for a pair of expensive rear corners. The discount I got was just a cup holder. Nothing you sold me was any good deal.
I ****ed up, you got my $ and you win, at least be a little helpful and show some respect to your customers. Thanks
Old 06-17-2011, 01:10 AM   #13
We can go at this all day, but facts are facts; I told you they are aftermarker. I told you they need work (broken tabs). What you show here is projector lights, i sold you projectors WITH HID that were selling at $400 on ebay at THAT TIME! I do NOT force anyone to buy anything, and provide as much information as possible. For the rear $75 is pretty cheap for an OEM red/clear light in mint condition, if you didnt think so you didnt have to buy them. But dont say i didnt help you with anything, or not showing any respect... I did 100% of what is exected of me, if you are still not happy, i'm sorry...but nothing more i could have done.
At this rate i will need to keep a tape recorder when i make sales...
