Old 06-06-2011, 11:32 AM   #1
BiBimBap
BiBimBap's Avatar
Phantom bulb problem...
I got the dreaded "Light Bulb Out" symbol on the dash and I'm trying to locate the actual bulb that's out.
I found one brake light (pax side) that was out - but when I took out the rear light module (the car was still running - brake was depressed) the bulb instantly turned on! Grr.. I looked at the wiring - but everything looked normal.
I reinstalled the light module - light was still working.
Turned off the car. Turned it back on - depress brake - then the bulb was out again!!!
Anyone with some advice??
BiBimBap is offline   Reply With Quote
Old 06-06-2011, 12:35 PM   #2
yellowfever3
try changing the bulb. make sure the bulb is the same rating as the one you take out
yellowfever3 is offline   Reply With Quote
