Old 05-12-2011, 01:04 AM   #1
iverson03tj
iverson03tj's Avatar
300mm Budget 'Bigger' Brake Upgrade
Anyone here ever tried this?
Does it really make a difference... What Carries are they
http://yhst-59326584023620.stores.ya...633003939.html
PREVIOUS CARS
Old 05-12-2011, 01:10 AM   #2
SiR
Vtec just kicked in
better off with some good pads imo
-||Old Crayons||-
Old 05-12-2011, 01:16 AM   #3
pfff...
OR for $250 you can get a set of big E46 330 used brake kit, with calipers, that are bolt on the E36! (with rotors and pads), but you must use 17" rims!
Old 05-12-2011, 09:50 AM   #4
slemmer
Driving in the fast lane
slemmer's Avatar
What brake upgrade do you suggest for my e46 330 cic? I'm running the OEM 18'"
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 05-12-2011, 10:35 AM   #5
dcramer
why do you want better brakes? Are you tracking it ?
Old 05-12-2011, 10:49 AM   #6
iverson03tj
Originally Posted by Eurostyle View Post
pfff...
Are they better than e36 m3 brakes?
PREVIOUS CARS
Old 05-12-2011, 10:59 AM   #7
slemmer
slemmer's Avatar
I would only do the fronts for that "extra" city/hwy driving stopping power. More of doing it to hop it up above OEM specs. Cheap end would be to up the quality of the pads/rotors without changing the calipers. Next would be larger diameter rotors and better calipers and brake lines.
'04 645cic
'00 740i Sport
Old 05-12-2011, 11:02 AM   #8
dcramer
You may want to do a little research on brake bias.... The engineers at bmw spent more than a few hours figuring out the exact balance for braking.
Candidly if you aren't tracking the car, then just make sure you have good pads, and tires. I'm pretty sure you can lock up the front wheels on pavement with what you have already
Old 05-12-2011, 12:18 PM   #9
You can go with the M3 Competition parts, unless you want to spend 10X more on BBK...I think the fronts were 350mm, around 13.5" with bigger calipers, more then enaugh for a steet car IMO.
Old 05-16-2011, 09:38 AM   #10
jon.e
jon.e's Avatar
Id like to know this aswell..
jon.e is offline   Reply With Quote
Old 05-16-2011, 11:06 AM   #11
e46 330 brakes are slightly bigger (but narrower in the front), they are so close I don't think it matters much.
E36 M3
Front: 315X28
Rear: 312X20
E46 330ci
Front: 325X25
Rear: 320X22
There is a BMW Performance upgrade for e46 330ci, but it isn't cheap.
It comes with Floating rotors and i believe requires 18'' wheels (not sure).
More info on them:
http://forum.e46fanatics.com/showthread.php?t=504694
Old 05-16-2011, 11:33 AM   #12
e36 M3 brakes and e46 330ci brakes are (practically speaking) identical. i'd go for the e36 ones cause they're even easier (i did, i love them). I recommend getting a M3 master cylinder for better pedal feel after completing the upgrade.
Old 05-16-2011, 02:16 PM   #13
DANIMAL
TYRE ETR
DANIMAL's Avatar
^^^ +1. I did the same, no regrets. I very much recommend the master cyl as well.
DANIMAL is offline   Reply With Quote
Old 05-16-2011, 04:24 PM   #14
sthomas
BMWCC 4928, BMWCCA 349578
Yup - e46 330 front brakes with e36 M3 master cylinder. Even uses the same brake pad as the M3 (e36 and e46) which means there are lots of options.
While you are doing this, put the brass bushings in at the same time. Makes a world of difference.
2002 540i M Technic
1993 325is RIP
sthomas is offline   Reply With Quote
