Old 05-06-2011, 09:06 AM   #1
Smitty
Smitty's Avatar
Looking for 2002tii front brakes
I'm upgrading to tii struts so a set of tii front brakes are needed. Anyone have something available?
Some old BMWs
Smitty is offline   Reply With Quote
Old 05-07-2011, 09:16 PM   #2
Kris
DSC off
Kris's Avatar
There are a lot of nice big brake options for tii struts. I am running an E12 5 Series setup which has plenty of braking power. Ireland and Aardvarc Racing both have really good options. I am thinking of changing mine but they won't be off anytime too soon. Good luck with the new suspension setup
05 330Ci ZHP
08 535xi Touring
Kris is offline   Reply With Quote
Old 05-08-2011, 07:47 PM   #3
Smitty
Smitty's Avatar
Hey Kris, thanks for the reply. Do you have any pics of your E12 setup? I'm interested to know if the caliper extends beyond the hub mounting surface. My new wheels won't work with calipers that protrude beyond the hub plane.
Some old BMWs
Old 05-08-2011, 11:42 PM   #4
Kris
DSC off
Kris's Avatar
I'll check for you about the fitment. I have some info I can send you on the E12 conversion.
05 330Ci ZHP
08 535xi Touring
Old 05-09-2011, 11:30 AM   #5
Smitty
Smitty's Avatar
That would be great, thank you!
Some old BMWs
Old 05-10-2011, 10:36 AM   #6
Kris
DSC off
Kris's Avatar
Take a look here:
http://www.bmw2002faq.com/content/view/44/33/
05 330Ci ZHP
08 535xi Touring
Old 05-10-2011, 09:33 PM   #7
Smitty
Smitty's Avatar
Hmm. Well, if the big brake kits would work, I'd be inclined to order from Aardvarc. Pics look very promising.
http://www.2002parts.com/html/front_disc_kits.html
Can I take a look at your E12 calipers sometime to confirm that there's clearance?
Some old BMWs
Old 05-10-2011, 11:51 PM   #8
Kris
DSC off
Kris's Avatar
The Aardvarc kit is good. Should be a pretty easy bolt up. I have his rear kit which required a bit of machining but that shouldn't be an issue up front.
I will pop a wheel off and take a pic tomorrow night.
05 330Ci ZHP
08 535xi Touring
Old 05-11-2011, 08:49 AM   #9
Smitty
Smitty's Avatar
LOL, this began as a grudge purchase. Now I'm actually psyched about doing the brakes. Good job, Kris
Some old BMWs
Old 05-11-2011, 09:59 PM   #10
Kris
DSC off
Kris's Avatar
Here's what they look like...the calipers are in line with the 5mm spacer I'm running.
05 330Ci ZHP
08 535xi Touring
Old 05-19-2011, 09:58 AM   #11
Smitty
Smitty's Avatar
Right, I ordered Aardvarc's "Option B" tii kit and a tii MC. Fingers crossed.
Some old BMWs
Old 05-19-2011, 10:23 AM   #12
Kris
DSC off
Kris's Avatar
Cool, Dave is a good guy. Does it come with the steel lines from the MC to the calipers? Tii's are dual circuit on the front brakes.
05 330Ci ZHP
08 535xi Touring
Old 05-19-2011, 10:45 AM   #13
Smitty
Smitty's Avatar
Do I need the steel lines? He offered a set of Stoptech braided lines that sounded good.
Some old BMWs
Old 05-19-2011, 11:09 AM   #14
Kris
DSC off
Kris's Avatar
I would take the braided lines (which go from the strut to the caliper. But you need to look into the hard line length (from the MC to the strut). Take a look here:
http://www.bmw2002faq.com/component/...ke+hard+lines/
Ask Dave if you need to replace the hard lines
05 330Ci ZHP
08 535xi Touring
Old 05-19-2011, 11:29 AM   #15
///Maluco
5erholic
///Maluco's Avatar
Is the tii MC the same as an E12?
If so, Smitty can have mine. You'll need to refinish it as it doesn't look so pretty...
My front and rear calipers may become available within the next month of so as well.
///Maluco is offline   Reply With Quote
