Old 06-13-2011, 10:34 PM   #16
JSPEC
Release bearing+Pilot bearing still available?
JSPEC is offline   Reply With Quote
Old 06-22-2011, 03:57 PM   #17
davericher20
black and blue
davericher20's Avatar
m20 coolant hoses?
Old 06-22-2011, 03:59 PM   #18
Sorry for the late reply, yes they are still available!
Originally Posted by davericher20 View Post
m20 coolant hoses?
No sorry, those were installed. But you can get them for cheap locally.
I do have 2 AC lines.
Old 06-27-2011, 08:40 AM   #19
Bump
Old 08-14-2011, 01:03 PM   #20
Still have The Following.
1) M20B25 Rear Main Seal From BMW Dealer - $20
2) 325i Release bearing + Pilot Bearing - $50 (retails for $75)
4) 318is Underhood insulation pads - $50
Front E30 FK springs - Never used, should be around a 40mm drop. (FK sent me 60mm instead of 40mm, i just never put these ones on) If you've seen old e30, you'll know what 60mm looks like. These should be a tad higher.
Voltage Regulator - Bosch 90amp $20
Blower Resistor Pack - Late model e30 - 4Pin 4 Speed - $30
BMW Parking Brake Spring/Hardware Kit - $30
Pick in Ajax (Salem/401)
Old 08-16-2011, 11:23 PM   #21
e30_moment
e30_moment's Avatar
a/c lines available?
e30_moment is offline   Reply With Quote
Old 09-11-2011, 12:24 PM   #22
iverson03tj
iverson03tj's Avatar
interested in the cluster! my rpm guage in mine doesnt work.... im assuming all e30's havee the same cluster? f not mine is 89 325ic
e39 M5 (s62)- Muffler Delete, Timmay Tips,
e30 325ic - Hard Top, Matte Black
e36 328is - (m52)AA S/c'd, M50 Mani, 3.23 LSD, M3 Brakes, Zimmer rotors, hps pads, Racing Dynamic Strut Bar, Depos, m3 Bumper, Intake, Spal fan, poly RTABs, Eibach Swaybars, Koni yellow, Mishimoto Rad, Silicone hose, Alumi T-housing, Depo w/LED Angels, LED tails, 12' Alpine Type R, Suede head liner, LTW Low rise spoiler
PREVIOUS CARS
92' 325is (m52) - M3 conversion AA S/c'd
'97 Euro Estroil E36 M3 Vert (S50B32)
Old 09-11-2011, 06:47 PM   #23
Sorry both clusters are sold.
Old 03-12-2012, 08:56 AM   #24
E30 Parking Brake Hardware kit sold.
Bump. Spring Cleaning, Whatever is left $20 each.
$20 Sale
Blower Resistor Pack - Late model e30 - 4Pin 4 Speed - $30 > $20
Front E30 FK springs - Never used, should be around a 40mm drop. (FK sent me 60mm instead of 40mm, i just never put these ones on) If you've seen old e30, you'll know what 60mm looks like. These should be a tad higher. $20
4) 318is Underhood insulation pads - $50 > $20
2) 325i Release bearing + Pilot Bearing - $50 (retails for $75) > $20
2 AC Lines (Condenser to Dryer, Dryer to Hardline) $20
or take everything for $100
Old 03-12-2012, 09:46 AM   #25
Ceeker
you're saying 60mm drop on the springs..isn't that like almost 2 inches?
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 03-12-2012, 11:59 AM   #26
No, 40mm.
FK sent me the wrong springs. My car had a 60mm drop, which ended up being alot more than 2 inches probably.
Old 03-12-2012, 12:24 PM   #27
I'll take the release bearing and the pilot bearing. Does it come with the felt ring and cover plates?
Old 03-12-2012, 12:46 PM   #28
I will double check, but I doubt I have it.
Old 03-12-2012, 03:58 PM   #29
e30_moment
e30_moment's Avatar
pm'd about a/c lines!
Old 03-12-2012, 04:01 PM   #30
Ceeker
pm sent
