Old 05-01-2011, 06:32 PM   #1
nopdog
2000 328i chokes
Hi,
I have a 2000 328i and over the past few months i've been having a problem with it while idling. It usually happens in the morning when I start the car to warm it up on cold days. The car shakes and the RPM drops and sometimes the car shuts down. If i give it a little bit of gas when the RPM drops the car is okay.
any ideas?
nopdog is offline   Reply With Quote
Old 05-01-2011, 10:48 PM   #2
oakville46
Appears to be a compression issue of some form. I had that once in a previous non-BMW car at turned out to be a vacuum hose was cracked and leaking.
oakville46 is offline   Reply With Quote
Old 05-01-2011, 10:59 PM   #3
tthai4
had the same problem in my 2000 328i last year, it was a small leak in the power steering, not too sure how that is causing the bad idling and start but got it fixed and the problem went away.
tthai4 is offline   Reply With Quote
Old 05-02-2011, 09:51 AM   #4
nopdog
is there someway i can check for the leaks on my own or do i need to bring it into a workshop?
Old 05-02-2011, 10:01 AM   #5
tthai4
the leak for me was very noticible, over night i parked in the garage and in the morning there will be a few drips of fluid on the ground.
