Old 04-14-2011, 09:07 PM   #1
fitter527
hates chrome
fitter527's Avatar
non bmw tranny info needed
the tranny oil cooler ruptured on my wifes american POS.the tranny cooling lines run inside the radiator so the tranny fluid and the coolant intermixed.
so i flushed the cooling system after changing the cooling system.that part went ok.then i proceded to drain the tranny but since there is no drain plug,i was going to drop the pan and drain the tranny that way.
when i was removing the bolts that hold the pan on the tranny,one of the corner bolts cracked the casing and a chunk of the case broke off.#$&@
my question is this,do you think this can be repaired with silicone.is there any pressure in the bottom of the tranny?i know there is pressure in the upper part of the tranny,but in the bottom where the fluid and pump is?
please help before i take a sledge to it.
forgot to mention its an auto.
fitter527 is offline   Reply With Quote
Old 04-14-2011, 09:41 PM   #2
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
JB weld the sucker.
Old 04-14-2011, 09:52 PM   #3
fitter527
hates chrome
fitter527's Avatar
thats what i was thinking of trying.its amazing how cheaply these cars are made.
Old 04-14-2011, 10:00 PM   #4
Axxe
Axxe's Avatar
The bottom is just a pan, no pressure on it other than the weight of the oil, JB weld the shit out of it, and then put silicone on it (but only on the outside). Should be fine.
Old 04-14-2011, 11:26 PM   #5
parm
Scarboro Mazda S&L
parm's Avatar
Sorry to tell you, but a crack in the case, will leak, jb weld could be a temp. solution, call BOB at Toronto Automatic 416 366 1345, see if he can help you out,
Parm
Old 04-16-2011, 09:27 PM   #6
fitter527
hates chrome
fitter527's Avatar
i put jb weld on it and everything is good.except,under braking there is a jolt when the car almost comes to a stop.when an automatic is accelerating the the gears go up,so when braking does it gear down?
Old 04-16-2011, 09:39 PM   #7
blk3
blk3's Avatar
make sure you have enough transmission fluid in it. it will do that if its a bit low. even hard left turn will cause a slip in the shift.
Old 04-16-2011, 09:45 PM   #8
fitter527
hates chrome
fitter527's Avatar
i checked the fluid and it was full.i was thinkin maybe the hiccup was due to air trapped in the tranny?
the wife asked me if it was due to something she did?i told her yes,for buying a north american throw away car.she didn't find it funny.
Old 04-18-2011, 04:06 PM   #9
MrRWD
make sure you check the fluid level in the tranny with the engine on.
... I'd never touch an automatic BMW.... makes chrysler tranny's look like a gem.
MrRWD is offline   Reply With Quote
