Old 04-12-2011, 06:21 PM   #1
Boxer2
The OPP loves my M5
Boxer2's Avatar
Exclamation E34 M5 no compression in Cyl. #3
Hey folks, I'm working on my E34 M5 and determined that there is no compression in cylinder #3.
I have never worked on a S38B36, I have been told it could need a valve adjustment.
Since I have no experience with this motor I was wondering if anyone that does have experience with the S38 would have any advice as to what the problem may be.
Also I would be looking for a reputable technician that is 100% confident they can do the job without damaging the motor, if anyone knows of a good tech please let me know.
thanks
Rene
My Garage:
1986 328is (M20 Stroker)
1986 535i (5sp all original)
1990 325iX (Mint 5sp all original)
1989 325iX (Winter auto X car)
1991 M5 x2
1988 M6
2001 740i (Supercharged)
1999 528iT (summer DD)
2004 X5 3.0i (winter DD)
Boxer2 is offline   Reply With Quote
Old 04-12-2011, 06:51 PM   #2
marek
Marcus Glarner is the man when it comes to M motors. He is in Port Hope, ON.
Doubtful that it would need just a valve adjustment, but not impossible. Valve clearances are easy to check yourself.
Google it and you will find a step-by-step DIY
marek is offline   Reply With Quote
Old 04-12-2011, 07:52 PM   #3
BigD
the misanthropist
BigD's Avatar
So all other cylinders are good, it ran fine otherwise? Probably not the problem then but I'd double check the timing just in case.
Do you have any oil in the coolant or vice versa, or coolant pressurization? I think best case is that the head gasket is toast.
Either way, to check it out I'd go to Auto Evolution in Oakville. If you need major engine work, then Progressive Specialties.
Old 04-12-2011, 07:54 PM   #4
BigD
the misanthropist
BigD's Avatar
That's true but make sure your will mentions who gets your car, since your descendants are likely to be the ones to receive the finished product (keeeeding Rudy... kinda haha)
Old 04-12-2011, 09:25 PM   #5
Boxer2
The OPP loves my M5
Boxer2's Avatar
I suppose I should re-phrase my words a little, I am only assuming there is no compression based on what I was told, I just know cyl #3 has an issue because it made no difference if the ignition wire was connected to the plug while the engine was running, yet when I pulled all the other wires(one at a time) it affected the way it ran.
I am not suspecting the head gasket as the oil and coolant are not mixing into one another....as for pressurization of the coolant, there is nothing coming out the overflow so I'm thinking it's fine.
My Garage:
1991 M5 x2
1988 M6
Old 04-12-2011, 09:29 PM   #6
BigD
the misanthropist
BigD's Avatar
Urr did you check the distributor, ignition wire and the spark plug? Spark plug wires on these go bad... cost a pretty penny to replace too.
Old 04-12-2011, 09:59 PM   #7
Boxer2
The OPP loves my M5
Boxer2's Avatar
I did pull the spark plug, and it looks as if it was firing normally.
My Garage:
1991 M5 x2
1988 M6
Old 04-12-2011, 11:00 PM   #8
Boxer2
The OPP loves my M5
Boxer2's Avatar
wires are good as well, lots of spark.
My Garage:
1991 M5 x2
1988 M6
Old 04-12-2011, 11:13 PM   #9
Tekals
DIYer
Tekals's Avatar
I had that kind of problem on my e30 325.
The motor had no difference in the way it ran by removing one the ignition wire. I had also noticed that the injector of the same cylinder was leaking.
Turned out that my injector filter was completly filled with rust such that there wasn't any fuel delivered by that injector. Check this and let us know!
Tekals is offline   Reply With Quote
Old 04-13-2011, 12:55 PM   #10
Boxer2
The OPP loves my M5
Boxer2's Avatar
Will check the injectors and report back, I'm really hoping this is something relatively simple to fix, it's nice out now and I was really looking forward to driving the M5
My Garage:
1991 M5 x2
1988 M6
Old 04-13-2011, 01:44 PM   #11
Perfection takes time sir
Old 04-13-2011, 01:45 PM   #12
MarkD
MarkD's Avatar
I'd guess that you have a bad valve or problem with a piston if you truly have no compression. You are near London Ontario? I don't know anyone out there, but I do know a very good BMW mechanic with lots of s14/s38 experience and you won't need to add your car to your will as he'll have it done fast! Or take it to Markus and wait a bit. Well maybe a few bits...
Who told you it could be no compression? Why don't you test it yourself? Anyway there is very little that is a simple cheap fix when this sort of problem occurs.
Old 04-13-2011, 01:55 PM   #13
^ Agreed. I am kind of surprised you haven't done a compression test yourself yet, as well as a leakdown to see whats going on inside. Beats running around trying to replace parts that probably aren't the culprit.
Old 04-13-2011, 02:00 PM   #14
BigD
the misanthropist
BigD's Avatar
LOL Yeah that's true, parts need to age like a fine wine before you touch them, for best results.
Old 04-13-2011, 02:10 PM   #15
BigD
the misanthropist
BigD's Avatar
Yeah, even if it is a low compression cylinder, that at best means a new head gasket so most people would delude themselves into believing it's anything but that until every possible test for something else is exhausted.
