Old 04-08-2011, 07:19 PM   #1
WlodeK84
E60 530i spacer question
I am looking at a set of spacers for the front and rear and I want to run my oem rims with them?
Does anyone know how many millimeters spacers I can put on , the car is running all oem suspension.
WlodeK84 is offline   Reply With Quote
Old 04-08-2011, 07:53 PM   #2
fastfive40
Spacers are going to depend on the current offset of the rim and where they sit in the fender, it really depends on alot of different factors, im assuming you want the wheels as flush with fenders as possible for an aggressive look?
fastfive40 is offline   Reply With Quote
Old 04-10-2011, 11:27 AM   #3
WlodeK84
Yes I want the rims to sit as flush as possible with the fender.
rims specs are
17 x 7.5 with 50 mm offset front and rear.
File Type: jpg $(KGrHqYOKnUE1OjcYQmiBNf4psM9Og~~_12.jpg (30.3 KB, 79 views)
Old 04-10-2011, 02:52 PM   #4
50 mm offset? Are you sure?
In any case 15mm are gonna push you pretty close to the fender edge.
Old 04-10-2011, 02:55 PM   #5
WlodeK84
Yeah I am sure that they are 50mm offset. So you say 15 mm is a decent size. I am looking to space out the rear with a 18mm and the front with a 15mm.
Old 04-10-2011, 04:49 PM   #6
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
I thought those wheels are 17x8 et 20? Unless they are for x-drive fitment.
Old 04-10-2011, 08:08 PM   #7
WlodeK84
your right they are 20mm offset my appologize to to the member above that asked me if I am sure about the 50 mill offset. Apperantly I was wrong.
Sorry
So to clarify, the rims are as follows :
17" x 7.5", 5 Lug, 120mm Bolt Pattern, 20mm Offset
Thanks for the input guys
Old 04-19-2011, 03:03 PM   #8
ipop07
Spacers guy
I have spacers, pm me with what thicknesses you decide to go with..
ipop07 is offline   Reply With Quote
