Old 04-08-2011, 07:10 PM   #1
Blades
Your opinion is to long
Blades's Avatar
Technology of engines may change ..
http://www.msnbc.msn.com/id/42460541...ce-innovation/
Despite shifting into higher gear within the consumer's green conscience, hybrid vehicles are still tethered to the gas pump via a fuel-thirsty 100-year-old invention: the internal combustion engine.
However, researchers at Michigan State University have built a prototype gasoline engine that requires no transmission, crankshaft, pistons, valves, fuel compression, cooling systems or fluids. Their so-called Wave Disk Generator could greatly improve the efficiency of gas-electric hybrid automobiles and potentially decrease auto emissions up to 90 percent when compared with conventional combustion engines.
The engine has a rotor that's equipped with wave-like channels that trap and mix oxygen and fuel as the rotor spins. These central inlets are blocked off, building pressure within the chamber, causing a shock wave that ignites the compressed air and fuel to transmit energy.....
-=[ BL/\DES ]=-
Old 04-09-2011, 03:24 AM   #2
SiR
Vtec just kicked in
its like if they redesigned the rotary...
IF...IF oil companies let this go through it could be a new era....but they didnt want to work with the rotary(which is a better design)...that got squashed... interesting to see how far this goes.
edit: the video is from 2009.. not going anywhere.
oil companies are not interested in making much higher efficiency engines...
you think engineers cant or havent come up with designs yet? lulz. just gets swept under the rug.
-||Old Crayons||-
Old 04-09-2011, 12:45 PM   #3
Those rotories are different. It was still a combustion engine. They are also less efficient.
Old 04-09-2011, 12:54 PM   #4
sirex
King Sirex
lies
Old 04-09-2011, 04:20 PM   #5
SiR
Vtec just kicked in
a rotary is a million times better design but no one else hopped on board. they didnt want to.
if most companies adopted it and it saw the collective r&d over the last 20 yrs...it would be pretty awesome. but that didnt happen so its wack
oil companies want you to drive semi efficient cars...just efficient enough to keep you happy but inefficient enough so they keep making huge profits.
-||Old Crayons||-
Old 04-09-2011, 05:17 PM   #6
sirex
King Sirex
whats so great about rotary engine? isnt that how prop driven aircraft work
Old 04-09-2011, 08:41 PM   #7
SickFinga
SickFinga's Avatar
He is talking about the Wankel engine
Old 04-09-2011, 09:02 PM   #8
sirex
King Sirex
whats so great about that? from the wiki pedia article seems to be less efficient, the only advantage is that its lighter.
Old 04-10-2011, 07:52 PM   #9
B6T
That's a radial engine.
Summer: BMW 135i M-Sport
Winter: 2004 Audi A4 Ultrasport 2.7tt
Year round: 6 cylinders, two turbos, and 6 speeds.
B6T is offline   Reply With Quote
Old 04-13-2011, 10:51 AM   #10
King Luis
The King.
King Luis's Avatar
rotary engines from the rx7 were notorious for bad milage. which is why they were not used. could also have patents on the motor restricting other manufacturers from building and selling similar style motors. i think emissions was also an issue...or it was oil consumption. can't remember which one exactly.
Mods: TBD.
Sold:2004 Silver Gray M3
Gone:1990 Brilliantrot 325is
Old 04-13-2011, 11:01 AM   #11
Blades
Blades's Avatar
The rotary engine also known at the Wankel engine does not use pistons. It was used in the rx7 and I believe in the rx8 as well. It would use more gas and oil because the apex seal eventually goes and the engine would need to be rebuilt. The rx7 would last to about 120,000km and start to lose significant power after that because of the apex seal. Its kind of like a piston ring in a sense which has metal to metal contact which would cause it to wear. That and the combustion in the camber.
But did you ever see how much a good modified rx7 can make in power and how fast they are. Its worth the trouble if you ask me. Plus because the engine is moving in a circular motion the car is very smooth once its on and has little vibration.
-=[ BL/\DES ]=-
Old 04-13-2011, 11:24 AM   #12
King Luis
The King.
King Luis's Avatar
people don't want to spend money every 120,000km to rebuild the motor and spend more money on gas and oil. they want efficient and maintenance free cars.
Mods: TBD.
Old 04-13-2011, 12:03 PM   #13
Blades
Blades's Avatar
the cost of replacing the apex seals is not as bad as you might think. It would cost you more to do the timing belt and water pump on some cars which is mandatory after 100-180k on some cars.
-=[ BL/\DES ]=-
Old 04-13-2011, 12:24 PM   #14
HavocSteve
Some private companies also buy-out the inventions that people make. Which in turn the inventor is now set for life and the companies don't have to worry about such items making breakthroughs with automobiles.
Old 04-13-2011, 12:26 PM   #15
NOTORIOUS VR
NOTORIOUS VR's Avatar
You know if the Germans invented something, tried it and gave up on it, it's probably gonna suck. Just sayin
