View Poll Results: What is the answer?
2 26 47.27%
288 29 52.73%
Voters: 55. You may not vote on this poll
Old 04-09-2011, 08:38 PM   #16
LOSO
When it's written as 2(9+3), it's already implied that the 2 belongs to (9+3). Anyone in engineering knows that the answer is 2.
The answer would be 288 if it were written as 48(9+3)÷2 =
Originally Posted by e36_freak View Post
I calculated this and got 288
i googled the equation and google's calculator comes up with this
(48 ÷ 2) * (9 + 3) = 288
I also tried it on WolframAlpha.com (Wolfram|Alpha is more than a search engine. It gives you access to the world's facts and data and calculates answers across a range of topics) and got to the same result
Input:
48\2(9+3)
Result:
288
EDIT*
for those getting 2. why do you multiply before dividing? i always thought you solve the numbers in bracket first and once that is done you either multiply or divide, whichever comes first. Multiply doesn't take precedence over divide...
type this into wolfram alpha: a/b(c+d)
What do you get?
LOSO is offline   Reply With Quote
Old 04-09-2011, 08:47 PM   #17
BigD
the misanthropist
BigD's Avatar
Originally Posted by sirex View Post
lol
48
---(12)
2
maybe a better way of looking at it is like that.
Correct. In order for it to be 2, it would have to be written as 48/(2*(9+3)). As is, it can be written as 48*(1/2)*(9+3) and NOT 48*1/(2*(9+3))
Old 04-09-2011, 08:47 PM   #18
SickFinga
SickFinga's Avatar
The only thing that is implied by 2(9+3) is that there is a multiplication sign between the 2 and the opening bracket.
Old 04-09-2011, 09:10 PM   #19
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
48/2(9+3) = (48/2)(9+3) = 288
48/2(9+3) = 48/(2(9+3)) = 2
Live happy knowing that both are right, and that this question is too vague.
Old 04-09-2011, 09:14 PM   #20
sirex
King Sirex
if brackets aren't inserted into the equation, you cant automaically assume that they are there, or that they belong there.
If you use any calculator with algebraic execution of functions, your answer will be 288.
Old 04-09-2011, 09:44 PM   #21
Axxe
Axxe's Avatar
My Ti-83+ says 288.
Old 04-09-2011, 11:27 PM   #22
woofster
This is the obvious answer:
woofster is offline   Reply With Quote
Old 04-09-2011, 11:43 PM   #23
sirex
King Sirex
Originally Posted by Axxe View Post
My Ti-83+ says 288.
want to make out? My TI-34 II says 288 as well.
Old 04-10-2011, 01:59 AM   #24
El Gato Liso
El Gato Liso's Avatar
your calculators are incorrect, because you're inputting the equation wrong.
seriously. with fractions, if there are any manipulations, you must do to the bottom what you do to the top. if you got 288 you are wrong since you're dividing the numerator (ONLY!) by 2 = 24.
fine, but given that you must also divide the denominator by 2 as well which those who are getting 288 aren't doing.
soooo, given what i said you should correctly have (48/2) / {[2(9+3)]/2} = 24/12 = 2.
as soon as the division sign is present, its a fraction. therefore....
48
(DIVISIONSIGN)
2(9+3) <---clearly you can just do the math 2(12)
48
(DIVISIONSIGN)
24
= 2
File Type: jpg 215862_1563864110218_1643820044_1156696_2439966_n.jpg (27.3 KB, 72 views)
R.I.P. E30
Old 04-10-2011, 02:20 AM   #25
SickFinga
SickFinga's Avatar
48
(DIVISIONSIGN)
48
(DIVISIONSIGN)
24
= 2
solve this then
42/2*10
Old 04-10-2011, 02:21 AM   #26
El Gato Liso
210
R.I.P. E30
Old 04-10-2011, 03:00 AM   #27
SickFinga
SickFinga's Avatar
210
So why the double standard?
Old 04-10-2011, 10:12 AM   #28
sirex
King Sirex
maybe a better way of looking at it for your el gatso, and a way that might make more sense is in a more complicated way.
48 / 2x
where x = 12
48/2x = 24x
You would still divide by 2 first to simplify.
24(12) = 288.
after you've simplified, then you can multiple the x.
Old 04-10-2011, 10:13 AM   #29
El Gato Liso
i knew you were going to say that captain obvious. i will explain....
there is a lack of brackets in that equation. there is not double standard at all.
BEDMAS says Division first, so 42/2=21, the Multiply next, 21*10 =210
if it were 42/2(10) then i would have treated the equation like a fraction...do brackets first then divide. 42/20 = 2.1
multipication and division roll together. addition and subtraction roll together.
R.I.P. E30
Old 04-10-2011, 10:19 AM   #30
El Gato Liso
48 / 2x
where x = 12
48/2x = 24x
24(12) = 288.
nahhh brooo..
if you're going to simplifiy 48/2x, then you would have 24/x. you cant just get rid of the "/" you know.
heres the expanded form of wat you used as an example.
48.......48........1
--- = --- x ----
2x........2........x
if X is 12...
48.......48.......1............48
--- = --- x ---- = ----......... = 2.
2x........2.......12...........24
multiplying fractions? numerator x numerator. denominator x denominator.
the answer IS 2.
R.I.P. E30
