Old 04-08-2011, 02:41 PM   #1
SICKBIMMER!
battery issue
I bought a 2000 328ci coupe. The previous owner had a interstate battery in there which died.
So now for a replacement battery i dont know which one to get. I dont know if its ok if i put in a bigger battery with more Ah, CA and CCA.
Basically i need to know the recommended battery for my car.
called the dealer they are not sure or the mechanics.
THanks for the help in advance
SICKBIMMER! is offline   Reply With Quote
Old 04-08-2011, 06:24 PM   #2
damameke
Call Rocco at RMP - http://www.rmpmotors.com/ he might have one in stock...
he changed mine...
Old 04-08-2011, 06:47 PM   #3
FFWD
Walmart - Energizer Max, part number 108-94R, $117. The book that hangs off the shelf where they keep the batteries lists it for for the various model years of E46, including the M3, and doesn't differentiate between coupe and convertible. I have a convertible, and it fits just like the stock battery. Works great so far.
Here's a guy on Rennlist that also uses it, he may be able to give you some long term feedback.
http://forums.rennlist.com/rennforum...placement.html
FFWD is offline   Reply With Quote
Old 04-08-2011, 07:30 PM   #4
Pierce330
Pierce330's Avatar
[QUOTE ]Basically i need to know the recommended battery for my car. [/QUOTE]
Go to interstate...their catalogue will tell you...I think that they are about $176 at interstate...So the dealership was not sure which one you need???
Pierce330 is offline   Reply With Quote
Old 01-09-2018, 11:43 AM   #5
FFWD
Thought I'd update. I still have that same Energizer battery in my car from 6 1/2 years ago. Only problem I had was during last month's holidays when it was parked outside (as it usually is) covered in snow undriven for over a week. It wouldn't start after that, but after charging it with my CTEK, it's fine and been problem free since. I might change to a new battery anyways as preventative maintenance, but not bad IMO.
