04-05-2011, 08:52 AM
#1
Car: E34iT, E30i
My E34 540iT/6 swap thread
04-05-2011, 08:53 AM
#2
Car: E34iT, E30i
Next I removed the ASC, which involved removing the hydro unit, switching from a dual to a single vane PS pump and plastic reservoir, and also re-routing the rear brake lines.
hydro unit still in
and out
cutting, bubble flaring, and bending new brake lines
turned out pretty clean
#3
Car: E34iT, E30i
04-05-2011, 08:54 AM
#4
Car: E34iT, E30i
04-05-2011, 08:57 AM
#5
Car: E34iT, E30i
One advantage of having the front end apart was being able to bolt the tranny to the motor before dropping back in. Not sure this would have been possible otherwise - it definitely wouldn't have been easy though.
I didn't get pics of the actual drop-in, but with two sets of hands and pry bar we got 'er done without too much hassle. I didn't want to take the exhaust manifolds off so it took removal of the AC lines on the pass. side and some careful maneuvering around the steering shaft to wedge it in there.
I also got all new shifter bushings and a 545i shifter
Mark D chip
and I found a pic of the flywheel
So here it is all back together
The other thing I wanted to do before firing it up was the rear end swap. The 540i uses a large case diff and larger axles than the 530i, which uses a medium case. Since I added a 3.15LSD from an E32 and had previously replaced all the rear bushings/mounts, I did a wholesale swap of the rear end. Don't have many pics, but I have to say that my trusty motorcycle jack was invaluable both in this case and also while dropping the auto tranny at the beginning of the project.
old rear end coming out
B&B exhaust before install
04-05-2011, 10:08 AM
#6
A true enthusiast
Car: E24E28E30E34E38E53
Nice work Nick  the car definitely went to the right home
let me know when you are finished with it, I'm ready to buy it back
[SIGPIC][/SIGPIC]
My Garage:
1986 328is (M20 Stroker)
1986 535i (5sp all original)
1990 325iX (Mint 5sp all original)
1989 325iX (Winter auto X car  )
1991 M5
1988 M6
2001 740i (Supercharged)
2004 X5 3.0i (The DD)
04-05-2011, 10:16 AM
#7
Car: 1995 525
Looking good. Farther ahead than I am.
'07 335i/6 - Addicted to boost
'95 525 - money pit/daily driver
'90 525 S52, ERT Powerdyne Stage 2 Supercharger - parts car
04-05-2011, 10:20 AM
#8
Car: E34iT, E30i
So with everything back together it was time for the moment of truth. I wasn't too worried about it starting because this is a really easy swap in terms of wiring - it's pretty much PnP. I used the auto harness from the touring though and it turns out that the car was produced in the last month before they changed to a different knock sensor, so I had to buy 4 new ones  Probably not a bad thing in the end though because the old ones on the B30 were all crusty and cracked anyway.
To get the car to start I had to remove the starter relay and jumper two of the terminals
there's actually a factory dummy relay for this that I'll end up getting once I track down the part #. Must have been from older manual models because I can't seem to find it on the donor, which is a '95.
I wish I'd taken a video of the start-up. I filled it with fluids, removed the fuel pump relay, cranked it a bit and then went for it. Fired right up! Was a bit rough/loud at first but that was to be expected from a motor that sat for over two years. After a bit it settled right down, idle steady @~700rpms and temp gauge rock solid @halfway! I was pumped, and after getting used to the sound of my 328is, I kinda forgot how nasty it sounds with that B&B exhaust. It's a beast!
So this is where it's at as of now. Things to do still:
-bleed brakes/clutch
-wire up reverse lights
-get new slip ring (messed mine up doing a steering wheel swap - more on that later)
-test drive!
I'm not planning on putting it on the road until probably the end of May, which will give me time to sort out small issues and deal with the interior. I'm swapping the sport seats and door panels from the donor, and the headliner needs to be re-done badly. I also have M-tech mirrors and sideskirts that I'll get around to swapping. More pics to come.
I also haven't mentioned suspension/wheels, so here's a hint/teaser:
More updates to come as they happen!
04-05-2011, 10:26 AM
#9
Car: E34iT, E30i
You can have dibs, but you might be waiting a long time
Get cracking! How far do you have to go? Seems like you bit off even more than I did - get that dash in yet?
04-05-2011, 10:30 AM
#10
Car: God's Chariot
Wow, awesome work Nick! Good job. Those wheels look
04-05-2011, 11:23 AM
#11
Car: 1997 328i
Nice work bro!
04-05-2011, 11:39 AM
#12
Car: E34iT, E30i
Thanks guys. Gonna try to take care of the brakes/clutch today.
05-09-2011, 09:09 PM
#13
Car: E34iT, E30i
mini update...
I think I jinxed myself by making this thread because things got super busy right after and I haven't had time to do much. Had some problems with brake bleeding but I think I've got it sorted now.
The main reason for this update, however, is that I got these today:
I'm pretty pumped to get this thing on the road now. I think everything else (besides work) is gonna have to wait. Hopefully I'll have a better update in the very near future....
05-09-2011, 09:32 PM
#14
Car: 1995 525
Sweet!
05-09-2011, 09:47 PM
#15
Scarboro Mazda S&L
Car: M5
Very impressive, cant wait to see it when its complete!
