Old 03-30-2011, 10:40 PM   #1
zalez05
changed gm, rm and 80 fusible link, and nothing
my windows doors locks runroof and wipers all stopped working....i changed all the component listed in title and still not working
Anybody got any ideas????
zalez05 is offline   Reply With Quote
Old 04-01-2011, 09:37 PM   #2
JINT
JINT's Avatar
under your rear seat, there are modules and lots of fuses, all of those are good? If those are all good, than there is some f@ckup with OBC and on the way to OBC, because all those things work through OBC.
1990 M5 Euro
You wash your car like it was your firstborn child, you tend to its needs like it was your own body, you protect it like it's your family, then you drive it like you stole it
JINT is online now   Reply With Quote
Old 04-02-2011, 01:34 AM   #3
Ike
It is most likely one or both of the relays in the General module - I had to remove the module from my E46 and have a friend (electronics expert) solder in two new relays. I then went through the key re-programming exercise (check the web for this procedure) I am sure the E39 is the same. I would check this website and email the owner for more specific details on the relays and module repair - incidentally - I bought the relays from him.
http://www.bmwgm5.com/
good luck and I hope this helps
Ike is offline   Reply With Quote
