Old 03-30-2011, 05:53 AM   #1
dcramer
tinting rear windows
PO previously tinted and removed the tint from the rear window.
Is it possible to tint rear windows over the antenna, and defroster without having it bubble ?
Old 03-30-2011, 10:56 AM   #2
bmwmck
there will always be some bubbling because of the defrost lines, but if you get a good job done than it can be kept to a minimum, and pretty much unnoticeable unless your right up close looking at it
bmwmck is offline   Reply With Quote
Old 03-31-2011, 09:13 PM   #3
///MG
///MG's Avatar
When I had my windows tinted on the E36 there was virtually no noticible bubbles. There might be in your case if the window was previously tinted unless its cleaned properly to remove all/any left over residue.
2003 BMW 330CiC CURRENT
1996 Toyota Camry FOR SALE
1998 BMW M3 IN EUROPE
2004 Mitsubishi Galant SOLD
1993 Plymouth Duster SOLD
///MG is offline   Reply With Quote
Old 03-31-2011, 10:18 PM   #4
CoEEzi
Some people have been known to sand down the dot matrix a little bit then applying the tint
02 CB M3: KWv3/ OEM LED RETROFIT / CCFL AE / Matte Black Grills / Gills / Dinan Exhaust / Dinan CAI / Dinan stg3 tune/ Dice / 18% Tint All around /
CoEEzi is offline   Reply With Quote
Old 04-02-2011, 08:37 PM   #5
agentM
Detailer, tint, Chipguard
agentM's Avatar
You shouldn't see bubble. It would be a bad tint job. There might be a slight gap where the defrost line but you should see it from standing point.
agentM is offline   Reply With Quote
