Old 03-26-2011, 08:12 PM   #1
djeurofest1
Where to tune boosted e46
I have a 01 330 that has a active auto supercharge kit, stage 2.
I had my ecu sent to them and they programmed it, I don't trust that as I have a few issues.
Where can I go to get my car dyno tuned? Any experience with this?
djeurofest1 is offline   Reply With Quote
Old 03-26-2011, 09:06 PM   #2
I'd probably just hit a dyno and log the AFR's. If the AFR's are good, you might have other issues. (Even if they're not, you still might have other issues.)
There's a couple of options for boosted tuning in toronto, unfortunately, i haven't exactly heard glaring reviews for any of them
Old 03-27-2011, 10:58 AM   #3
agentM
Detailer, tint, Chipguard
agentM's Avatar
You don't trust AA tune or your car have a few issue to clear for the tune?
agentM is offline   Reply With Quote
Old 03-27-2011, 12:21 PM   #4
djeurofest1
I have a few issues, had the blower for a couple years and it was never good.
So yes I don't trust the tune.
After a long overhaul, changed a couple things, my eml light keeps coming on after I give it, over 3-4k rpm
It seems to be cutting off the fuel around 5500 rpm
It bogs on lower rpm,
Old 03-27-2011, 12:54 PM   #5
So after you changed stuff, it stopped working, and suddenly now its the tune that's causing it? doesn't seem likely.
Old 03-27-2011, 02:44 PM   #6
djeurofest1
Well I have never had the car running correctly, my eml light kept going on, just not as often.
I had my blower sent in for leaky seals and it got lost in shipping.
Now I got a new blower from AA and I'm not sure if the pulley size matches the tune and I added a massive fmic.
I changed my exhaust... From the cats back just straight to a supersprint m3 exhaust
If I can get someone to tune it, I'll know for sure it will be correct
Old 03-27-2011, 03:00 PM   #7
kevin325
AMG ETR
kevin325's Avatar
this sounds like a boost leak to me - do a smoke test on the system to determine if there are any leaks. I used to have the exact same issue on my non-M motor S/C kit and it was 110% due to bad install/boost leak.
where did you have your kit installed?
kevin325 is offline   Reply With Quote
Old 03-27-2011, 08:08 PM   #8
agentM
agentM's Avatar
Do you have a wide band and boost gauge?
