03-25-2011, 12:33 AM
Car: 320i
lf: ms43 330i dme
Looking for an ms43, can ONLY be from a 330i, please let me know what you have.
Thank you.
Also I am only interested in the dme, none of that ews crap and other stuff.
03-27-2011, 06:21 PM
Car: 320i
bump!
03-28-2011, 12:19 AM
Car: 2007 328XiT
I have it. From a 2000 330i. PM me an offer.
03-28-2011, 01:36 AM
Car: 330ci SC, M5 Touring
Thank you.
FYI, they are NOT 330 specific! It even has the same part # as the other M54's (not 323/328!)...So anything from 320/325 will be the same. Newer 330 also wont work with early ones, just tryed that yesterday...
03-28-2011, 01:42 AM
Car: 320i
the hardware is the same, but the maps/software that is on them is different. ex. the 320i ecu apparently has older shittier software then the 330 ecu. All my info has been from what others have told me though, such as RMP and MarkD which I see as reputable sources. Also a place called Advanced Knowledge Automotive in Richmond Hill.
Also, newer 330 use Ms45 i believe. So thats probably why it didnt work for u.
03-28-2011, 01:57 AM
If they use the same part # from the factory, how is anyone to know if its made for 325 or a 330??? Real OEM has the same listings for all 320/325/330 DME...Software/maps changes every year, this is why the change part #'s so much...Reputable places have told me the DME is 5spd/auto specific, but according to part #'s they are not, and i have seen it work.
03-28-2011, 01:04 PM
Car: 74 tii, 93 M5x2, e90
The VIN is on a label on each DME. Enter that into any VIN decoder and you can tell what sort of car the DME came from.
03-28-2011, 04:33 PM
Car: '04 330CI 6-speed
If one from a '01 325Ci will work for you, I have one.
03-28-2011, 04:42 PM
I know that! Buy if I go to BMW and order by part #, how do they know what car it's going to, if the part # is the same on both parts!?
03-28-2011, 06:58 PM
#10
Car: 2007 328XiT
I'm guessing they flash it to the match the VIN, hence the engine that the car has before they hand it over to you at the dealer.
03-28-2011, 07:00 PM
#11
That is correct. When you get a virgin ECU, you have to flash it with the proper code for the car it is going into. If you use a GT-1 and Progman/SSS, it asks you for the VIN of the car and then it knows how to properly program it.
03-28-2011, 07:01 PM
#12
They probably don't know unless you tell them. But you should not have to as it would be flashed once it's installed in the car. The base part number and the programmed parts numbers differ.
