Old 03-22-2011, 03:29 PM   #1
abrial
Excellence Auto Collision
abrial's Avatar
Send a message via MSN to abrial
Aftermarket head unit problem
Hi guys, i just decided to replace oem radio on my new 325, so I installed sony aftermarket radio (i pull it with wiring from my previous e46) but only am/fm radio works no cd/usb..actually it works but no sound from speakers only from cd/usb, radio works fine.
What i have to check? Maybe its because this car has harman/kardon sound and privious one not?
Thanks a lot
abrial is offline   Reply With Quote
Old 03-22-2011, 10:02 PM   #2
slemmer
Driving in the fast lane
slemmer's Avatar
Is the CD unit built in to the radio or separate?
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 03-23-2011, 07:06 AM   #3
abrial
abrial's Avatar
Yes its the same head unit, i have absolutely no idea because i checked everytnig, i even tried to connect my friends radio and it has the same problem: i cal listen just the radio not cd or usb, the dash shows that it plays but i have no sound...
Old 03-23-2011, 12:22 PM   #4
uzi577
RUNING BOOST
uzi577's Avatar
If it is a late model radio
you can change the output options for the sound
try it see if you radio output option match the cd or usb
uzi577 is offline   Reply With Quote
Old 03-24-2011, 08:58 AM   #5
abrial
abrial's Avatar
No unfortunaly there is no output settings...
So anybody has aftermarket head unit with h/k sound system?
Old 04-14-2011, 12:57 PM   #6
bkizer44
bkizer44's Avatar
Well your problem is that you have not connect the remote amp wire. The blue wire of the aftermarket harness should connect to the blue/white wire of the factory harness. This will power on the amp therefore allowing sound.
I however have another problem in my '00 323i. After hooking up an alpine HU, my unit still doesn't have sound. When I connect sound through RCAs everything plays just fine but when I try to use the speaker wiring, I hear nothing. Can't figure this out for the life of me.
bkizer44 is offline   Reply With Quote
