Go Back   maXbimmer Forums > Specific Regional Areas > Windsor, Ontario
Old 03-20-2011, 07:18 PM   #1
lost
lost's Avatar
BMW e30 Code Reader anyone have?
Does anyone in the Windsor or the surrounding area have a BMW code reader that will work on the e30?
I've finally got around to bleeding the brakes and getting the car so I can move out of my garage and such, and I have a check engine light on.
Changed my gear oil and oil/filter today so I'm getting my shat sorted.
If anyone will be kind enough to lend it or stop by and give me a reading I'd be much appreciated.
Jeff
lost is offline   Reply With Quote
Old 03-22-2011, 09:54 AM   #2
unom
Code Reader
I've got one that you can try, but did you do the "Stomp test"?
Here's a link:
http://www.pelicanparts.com/bmw/tech...de_Reading.htm
Basically, you just turn your key to ON, then step on the gas pedal 5 times. Your Check Engine light will then read out all your error codes.
I've got a reader (need it for my E36), but I just use the stomp test myself.
unom is offline   Reply With Quote
Old 03-22-2011, 09:59 AM   #3
lost
lost's Avatar
Sweet, I've heard about the stomp test, but wasn't exactly sure what it was, so I'll give it a try tonight.
Here's a link:
Old 03-23-2011, 12:53 PM   #4
lost
lost's Avatar
Tried the stomp test and didn't work, don't know if I did something wrong or what, but seemed pretty straight forward.
I'll pm you about the Code Reader.
Old 03-24-2011, 07:04 PM   #5
Nerk
Nerk's Avatar
I think the stomp test only works on > '88 cars... what year is yours?
Old 03-26-2011, 08:44 PM   #6
lost
lost's Avatar
It's an 88 but I ended up borrowing the code reader from unom and ran it tonight and turns out theres no problem so I cleared everything and started and my light is off, but I'm going to fill it up and move it out of the garage tomorrow and let it run for a while to make sure it doesn't come back on.
