Old 03-18-2011, 08:09 PM   #16
SiR
Vtec just kicked in
lol. Just asked. Brake fluid is like oil in a lot of ways. most of the top brands are decent...and everyone has the flavour they like.+ doesnt hurt to carry a variety of products.
ate superblue is great product with longer life. Its cheaper and resists moisture better.
I wasnt looking to make this a x vs y...just asked if you can get it in. Both are good products.
The only reason ate is not dot is because of the colour...
funny, the brake fluid reservoir on my M3 says "ATE"
http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
-||Old Crayons||-
Old 03-22-2011, 12:14 AM   #17
richie_s999
So for those interested I will be picking up a case or two this Friday and can deliver to your place this weekend!
Old 03-22-2011, 12:18 AM   #18
Dissembler
Dissembler's Avatar
sent you a pm
S52 E30
Old 03-22-2011, 06:43 PM   #19
Originally Posted by MarkD View Post
Rudy,
I thought you told me you re-use the brake fluid that your dad takes out of the M1 after a race.
Shhhhhhhhhh.... don't give out my secrets now! lol
Old 03-26-2011, 11:17 AM   #20
richie_s999
Fluid is in, John see you tonight, Dissembler see you tomorrow, everyone else drop me a PM to set something up!
Old 04-06-2011, 08:05 AM   #21
dcramer
Trev... stock dot4 boiling point is 150f-200f once you hit that temp its toast!
I'm confused, prestone DOT 4 from crappy tire has an advertised boiling point of 478F. Are they not telling me something ?
Old 04-06-2011, 08:13 AM   #22
dcramer
Ultra efficient in the rain:
Very high wet boiling point 420°F / 216°C
Rich
Was curious about the rain thing. Doesn't make sense that the boiling point would change just because it is raining outside. Found this on wikipedia http://en.wikipedia.org/wiki/DOT_4
wet boiling point defined as 3.7% water by volume
What I read here is that when the brake fluid has absorbed water then this is the boiling point. Is that how others read it ?
Dave
Old 04-06-2011, 10:03 AM   #23
LoL wet boiling point has nothing to do with rain. Water shouldn't be in your brake fluid or you got bigger problems. Wet boiling point should never matter unless you plan to never change your brake fluid.
WET VS. DRY BOILING POINT
The term boiling point when used regarding brake fluid means the temperatures that brake fluid will begin to boil.
WET BOILING POINT
The minimum temperatures that brake fluids will begin to boil when the brake system contains 3% water by volume of the system.
DRY BOILING POINT
The temperatures that brake fluid will boil with no water present in the system.
Old 04-06-2011, 10:09 AM   #24
dcramer
Interestingly enough Motul 600 has a higher wet boiling point than Motul 660. So for track junkies who are willing to flush every track day 660 is better since it has a higher dry boiling point, but for people less willing to flush 600 would be a better bet.
Old 04-06-2011, 01:20 PM   #25
richie_s999
660 is also over $50 a bottle, very pricey, for that litle higher number.
If you want a bottle or two of 600 I'll be heading to London on Saturday if you want to meet up.
Old 06-05-2011, 03:58 AM   #26
doogee
doogee's Avatar
Yes it does actually. Motul themselves say it. The reason being, when driving in the rain, there is much more moisture in the air that will enter the system since a brake fluid reservoir is vented.
Dakar M3 Track Build Thread
Old 06-05-2011, 05:35 AM   #27
dcramer
sorta .... Wet boiling point is defined as the boiling point at a specific amount of water in the brake fluid. So sorta... Once your brake fluid has absorbed that much water which may come from driving in the rain (in fact you don't have to drive. Just being in a humid environment ) then the wet boiling point comes into play
