Old 03-12-2011, 08:57 AM   #1
scotty328ci
Arrow injector upgrade
hey there
im looking into doing a tune up prior for the spring and summer weather come along, i was looking to upgrade the injectors but was wondering if there were injectors out there that made it so i wouldn't have to change to much to the motor !
or would it be best to just stick with the oem injectors all together?
thanks
scotty328ci is offline   Reply With Quote
Old 03-13-2011, 02:55 PM   #2
uzi577
RUNING BOOST
uzi577's Avatar
I am not sure on that, but bigger injectors to far away form stock will require a DME(ECU) reprogramming. Stock injectors are sort of an odd shaped the nosel sit were deep inside. Go for a stock replacement, less problems. By the way to get injector out is a bitch, make sure you are inside and have a lot of patients and a bit of a strength, they don't come up out easy.
uzi577 is offline   Reply With Quote
Old 03-15-2011, 08:29 AM   #3
scotty328ci
yaa stock seems like a better way to go! thanks for the advice !
Old 03-15-2011, 04:11 PM   #4
Renboy
The only time injectors need to be upgraded is if you're running boost. If there's nothing wrong with your current injectors, don't replace them.
Old 03-22-2011, 01:00 PM   #5
MarkD
MarkD's Avatar
That's correct. Just leave the stock ones in there and replace with the same if you have defective ones.
Old 03-24-2011, 11:33 AM   #6
new member
Replacing injectors is NOT part of the scheduled maintenance routine.
I have no idea why you'd want to replace them if yours arent leaking or cracked.
