Old 03-11-2011, 05:19 PM   #1
tlinkletter
tlinkletter's Avatar
E39 - Driving with gauge pod out?
I've got a 1998 540i with the dead pixel issue on the gauges. I want to send them away to be repaired but can't be without the car. Can you drive it without the gauges? Or could I swap in a spare set I have and then put the original's back in without throwing off the odometer?
tlinkletter is offline   Reply With Quote
Old 03-11-2011, 10:42 PM   #2
Dado 540
Dado 540's Avatar
Putting in a spare unit may trigger the mileage manipulation dot! Mileage is stored at three loaction in the car one of them being the odometer. If you place your spare and turn the car on the computer will perform a check to see if the three storage locations match. It is doable to put your spare unit in however it will need to be programmed.
Now im not sure what would happen if you had the manipulation dot iluminate on your spare odometer and then you put your original back in. Would it still be on, i am not sure.
E39 540i Sport
Old 03-12-2011, 10:40 AM   #3
tlinkletter
That's what I was wondering as well. Maybe I'll just have to have the dealer do a prog on both of them so it all stay's synced. I really don't want to mess it up.
Old 03-22-2011, 07:44 AM   #4
tlinkletter
For anyone else's reference I was at the dealer and he said to just go a head and swap them. He can program them after the repaired unit is put back in.
