Go Back   maXbimmer Forums > Classifieds > For Sale > Exterior Body/Lighting
Old 02-28-2011, 09:03 AM   #1
dcramer
LF:coupe drivers door handle
Broke mine trying to replace the trim. Now I know how to do that, but left with a broken door handle.
Actually does anyone know what the door handle microswitch does ? That's all that is broken off.
Old 02-28-2011, 09:22 AM   #2
E36is
'OldSchool..'
E36is's Avatar
just curious, can the door handle trim be interchangeable on either sides?
Old 02-28-2011, 09:35 AM   #3
dcramer
The outside trim, no. The rubber is however. I bought mine from the guy on ebay. Not a great fit but it works. You need to make the hole bigger for the lock.
Old 02-28-2011, 10:21 AM   #4
Are we talking inside or outside handle?
the outside black handle is interchangeable; the inner door handle trim is also. I can't recall if the actually inner handle part is as well since it's been a while that I did one. the door handle "mechanism" I don't believe is interchangeable.
the micro switch is to activate the interior lights before stepping into the car. allowing for a delay of approx 8 sec. and then goes out or when you put the key into the ignition it will go out immediately. most of them are broken and don't work.
Old 02-28-2011, 10:23 AM   #5
dcramer
Yes, the outside. And now that i think about it, it should be interchangeable.
Thanks for the info.
Dave
Old 02-28-2011, 11:11 AM   #6
E36is
'OldSchool..'
E36is's Avatar
well then, i have a complete pasenger door with the trim your looking for. I dont have time to disassemble but you can take the entire door with window and working motor and microswitch for $75?
Old 02-28-2011, 11:14 AM   #7
dcramer
tempting. I'll let you know. Do you remember if the window had any problems going up ?
Dave
Old 02-28-2011, 11:21 AM   #8
E36is
'OldSchool..'
E36is's Avatar
when i had this on the car the window went up and down with no problem, but i exchanged doors since the door lever latch (aluminum) inside broke so i replaced the entire door with a working door, but the trim is perfect. When i took the door off the window was operating smoothly up and down, but i cant garantee you that now as its been 2 yrs and its in storage in the basement, may need to be lubed. anyways, if your interested let me know.
Old 02-28-2011, 01:12 PM   #9
You do know not every car out there is an e30 right!? Everything you say relates prety well to the e30, but not so much other models...
