Old 02-24-2011, 11:56 PM   #1
///M318ti
///M318ti's Avatar
Question e36 CAI and clutch..
1.Hi there, my clutch bearing is dead ans I'll buy an OEM clutch/PP/bearing kit. The thing is that my clutch pedal is very hard.. which I find wonderful! Will it be the same with a new clutch kit?
2. I want to buy a CAI and I found the Cosmoracing one. Did anybody test it? (The normal model is 3" and the Evo one is 3.5"...)
My Bimmer is a e36 318Ti 1.8 M42 1995, thanks!
///M318ti is offline   Reply With Quote
Old 02-25-2011, 06:21 AM   #2
dcramer
Do the 318's have dual mass flywheels ?
Old 02-25-2011, 06:27 AM   #3
dcramer
I looked it up and apparently it does have a dual mass flywheel. I personally would not keep this flywheel. I'd buy an aftermarket flywheel and clutch. The labour is the majority of the work here and dual mass flywheels are only meant to last as long as the clutch.
Old 02-25-2011, 02:38 PM   #4
///M318ti
///M318ti's Avatar
Oh that's bad.. how much does a dual-mass flywheel cost? :/
Old 02-25-2011, 04:06 PM   #5
dcramer
Well I wouldn't recommend replacing it with another dual mass. I'd replace it with a lighter single mass.
Dave
Old 02-25-2011, 11:41 PM   #6
///M318ti
///M318ti's Avatar
thanks, I'll tell you what I finaly did! It should be done next week! Do you know, for the pedal resistance?
Old 02-26-2011, 06:53 AM   #7
dcramer
Pedal resistance will be depend on the spring plate you put in.
