Old 02-22-2011, 09:40 AM   #1
muxruk
muxruk's Avatar
Question E39 seats replaced caused airbag light on and heater not working .... HELP!!!
Ok, so I replaced yesterday seats on my e39 with basically the same one I had but in mint shape, so I have one small yellow conector under passenger side which doesn't connect to a new seat as there is no plug for it, I was wondering what is it for if someone know?
But the main issue is that my heated seats not working , u press the heated seat button it lights on and after automatically shuts off in few seconds, on both sides ...????
Also my airbag light stays on all the time now...
So swap ended up bringing not much happy feeling as was excpected ...
Fellows please help , any ideas ? I assume that's some eletronical issue... Ecu doesn't recognize new seats .... Is there some important sensor in seat maybe I need to take of my old seats and install on new ones....
I dunno.... (((((((((((
muxruk is offline   Reply With Quote
Old 02-22-2011, 12:21 PM   #2
BimmerGuys
BimmerGuys's Avatar
You need a scanner to reset airbag light, and you have a bad connection somewhere that's the reason why heated seats doesn't work,
BimmerGuys is offline   Reply With Quote
Old 02-22-2011, 01:22 PM   #3
Most likely you got the wrong seats for the car, as not all E39's are the same; they look identical but wiring is not! You also did the job without disconnecting the battery, this is why the airbag light is on (happens every time you unplug a safety device such as bag or seatbelt buckle).
Most models E30 E36 E46 E90 E92 E93 E28 E24 E34 E39 E60 E61 E32 E38 E65 E66 X3 X5 M3 M5 Z3 Z4 F30 F32 F10 F01
Old 02-22-2011, 01:43 PM   #4
muxruk
muxruk's Avatar
Yeah actually I didn't disconect the battery ....
I did disconect it overnight hoping the system gonna reset and everythig gonna work but it didn't...
So ok, I will reset the lights... What do I do with the seats heater... Is it possible to use maybe some wiring from my old seat ... Any ideas what exactly needs to be replaced
Cuz the conectors looked exactly the same and the power options work correct, I got the seats from 97 528i mine is 98 528i...
still wondering about that second small yellow conector under passenger seat
Thank you guys ! U r being very helpful !
Old 02-22-2011, 01:50 PM   #5
Quack
Wheelman
Quack's Avatar
yellow connectors normally mean SRS, it can be anything from airbags to seatbelts/buckles.
Old 02-22-2011, 09:38 PM   #6
muxruk
muxruk's Avatar
ppl common,
someone knows how to fix this heated seats ?
Old 02-22-2011, 11:14 PM   #7
Originally Posted by muxruk View Post
ppl common,
Yes, but it's a pain, and will cost 5x more then buying working seats!
Old 02-23-2011, 01:48 AM   #8
MLue1
MLue1's Avatar
ppl common,
I doubt many have ventured into this area. If it was me I would pull both seats and trace and compare the wiring and pins on the connectors. Even if someone were to tell you what to do you would still have to do alot of this work anyway to splice the connections or to change the pin configuration on the connector(s).
Mark
'99 E39 540iT
Old 02-27-2011, 11:49 AM   #9
daveyto
daveyto's Avatar
i haven't read the whole thread but i will reset the SRS light for you for for free.
Just send me a PM or call me fouronesixeightthreefourninefivenineeight
dave
daveyto is offline   Reply With Quote
Old 03-02-2011, 12:41 PM   #10
spencercat
You'll need to reset the SRS code with a scanner. I got the CARSOFT software on the 'net and bought the connector on ebay to attach my laptop. I think the cables cost about $50, but I spent a few hours getting it to all work right. No time to get into it, but if you search bimmerforums you should find what you need.
You may also need to fool the car into thinking the passenger seat sensor is OK. My SRS light was triggered by a failed passenger seat sensor and I was able to reset it after wiring in a diode/rectifier/capacitor combo to the wiring harness. Search around for that solution if you find the seat sensor is kicking out the code and you can't get it to reset. HTH
spencercat is offline   Reply With Quote
