Old 02-19-2011, 03:20 PM   #1
E34-Babanca
E34-Babanca's Avatar
Exclamation *HID issue with my BMW E34 540i*
Hey guys,
I have installed MaxCar HID's in the car. They work great but one issue, sometimes the passenger bulb wont turn on.
I would have to turn off the car and turn it back on, and then it would work.
Anything i can do to fix that?? It wouldn't be as annoying if i had my DRL's deleted but I cant find anyone to do them for me under $100.
Please let me know,
thanks guys.
E34-Babanca is offline   Reply With Quote
Old 02-20-2011, 02:19 PM   #2
MLue1
MLue1's Avatar
You have a burnt wire somewhere, it probably has some carbon it from being broken / loose. I had to fix the spade connector on the positive side head light, to track it down you have to wiggle small sections until you find the bad area.
Mark
'99 E39 540iT
Old 03-09-2011, 02:36 PM   #3
Qube
RMP will do DRLs for less than $100. If it's only recently started to happen then it's either a dead bulb or ballast. Swap them left to right to check. If it's always been that way then it may be the LKM switching it off. You'll know this because you'll get a low beam error and it will always turn off after the same interval.
Old 03-09-2011, 07:20 PM   #4
E34-Babanca
From what I hear, its not as easy to do DRL's on a E34 compared to other models, but I'll give RMP a call for sure.
And I've been having that issue from day one and I have a feeling worn out wiring would be the issue as the lights don't turn off while driving or anything, but whenever i turn the key to start up the car, usually the left bulb doesn't go on..so i turn off the car and crank the car up and then everything is fine.
Old 03-09-2011, 08:12 PM   #5
Qube
Ah E34. Have you seen this yet?
http://www.maxbimmer.com/forums/showthread.php?t=127576
A fail start can happen with a bad ballast or bulb. Do a bulb swap to see if it follows the bulb first.
Old 03-09-2011, 09:25 PM   #6
E34-Babanca
I'll switch the bulbs and we'll see what happens.
Old 03-12-2011, 08:07 PM   #7
E34-Babanca
Bulbs switched, problem still exists. Maybe try out some harness/ relays..?
Old 03-13-2011, 09:57 PM   #8
525Inc
i was having the same problem i relocated my ballast and tucked it away from the hood hinge and they are working fine now maybe one of the wires are getting too much tension that's what happened to mine hope you solve it!!
525Inc is offline   Reply With Quote
Old 03-14-2011, 10:00 AM   #9
E34-Babanca
May I ask where you relocated the balasts exactly? Thanks
Old 03-18-2011, 09:28 AM   #10
525Inc
i tucked them behind the fender i will snap a pic for ya
Tags
bmw, drl, e34, hid
