Go Back   maXbimmer Forums > Specific Regional Topics > Quebec/Gatineau/Ottawa
Old 03-22-2012, 02:55 PM   #286
Aero
Aero's Avatar
I'm familiar with the use of peel ply in vacuum bag layups with male or female molds; we use a lot of it for the formula car at Carleton. Pretty usefull stuff! How would you have used it in this layup?
1996 328is Track Toy
2005 RSX Daily Driver
My Youtube Channel
Aero is offline   Reply With Quote
Old 03-22-2012, 03:18 PM   #287
DIY
Permanently Dirty
DIY's Avatar
Well on the Ryerson formula car we don't vacuum the nose... Just lay the peel ply ontop of the wet layed fabric.. To help it stick you can put a touch of resin ontop of it (to make sure its attached to all of the surface) and it still comes off nicely
Old 03-22-2012, 03:32 PM   #288
Aero
Aero's Avatar
Is that using a male or female mold? I guess male since you're concerned with the outer surface in that case. Never thought of using peelply on an out-of-vacuum cure, thanks for the idea.
Does it follow compound curves well without vacuum pressure, or do you lay it down in strips?
Chris, is most of the bondo you're using to fix the surface finish or to fill large-scale low spots from the foam plug? The surface didn't look like it needed too much work last time I was over...
My Youtube Channel
Old 03-22-2012, 03:47 PM   #289
DIY
Permanently Dirty
DIY's Avatar
Depends on how you cut the sheet, but you just gonna peel it off so if you fold it ontop of itself it doesn't matter too much, with a little extra resin it will stick wherever you leave it .. Strips are possible but if you know what your doin you don't need it (band aid fix) ... Female or male makes no diff really, its the same process just no vaccume
Old 03-22-2012, 03:59 PM   #290
Chris916
Chris916's Avatar
Hmm interesting stuff. Good to know for next time. I just skim coated the sides/top. There is not a lot of bondo on there, just enough to fill in the little pinholes.
1991 318is - My Track Car Build
Chris916 is offline   Reply With Quote
Old 03-22-2012, 04:13 PM   #291
DIY
Permanently Dirty
DIY's Avatar
And on that note, bondos good for the flow and shape of panel so I uget why youed use it freely.. But if your just filling pinholes gelcoat/primer is the way to go.. Again just food for thought, car looks awesome!
Old 03-22-2012, 04:25 PM   #292
North
The peel ply would make the finished product paintable without sanding so you won't have to worry about exposing the fibres or damaging the part by excessive sanding either.
If you use a peel ply, I would make sure to use a bleeder fabric for excess resin to bleed off into, otherwise it could pool over your peel ply and give you some issues with removal.
North is offline   Reply With Quote
Old 03-22-2012, 04:43 PM   #293
DIY
Permanently Dirty
DIY's Avatar
Agreed, although, I've always used a weave and impregnated the fiber with resin off the part, then, with help transferrd it onto the mold ... It helps to make sure there's only a min amount of resin used but the cloth is fully saturated... Never had epoxy dripping
Old 03-22-2012, 05:12 PM   #294
North
If you're not using a vacuum bag, then it might not bleed out as much. With an intitial 50:50 epoxy to fibre mix it should bleed to an ideal 40:60 if all goes well, so the epoxy would need a bleeder fabric over the peel ply to absorb it.
Impregnating the fiber off the part is definitely the way to go.
Old 03-22-2012, 06:56 PM   #295
Chris916
Chris916's Avatar
Thanks for the tips guys. I'm new to composite parts (first time ive ever touched fiberglass lol) so this is good info.
I did a bit of a prime check today, and it doesnt look half bad. Apart from some tiny pinholes you can see up close. I have some filler primer stuff that i'm going to try out.
Old 03-31-2012, 06:00 PM   #296
Chris916
Chris916's Avatar
Cage is Complete! This week i managed to mount the passenger seat bracket, welded in all the eye bolt plates for the harnesses, and gusseted the passenger X bar. Which meant that today I got to paint!
Interior is all done. Just waiting for the paint for the exterior now (John Deere Blitz Black). Time to start rebuilding the m50!
Old 03-31-2012, 06:32 PM   #297
bmwconnect
BMW Tuner
bmwconnect's Avatar
I have to see this in person... Amazing job!
Old 04-01-2012, 12:17 AM   #298
This has turned epic.
Old 04-01-2012, 08:03 AM   #299
Chris916
Chris916's Avatar
Thanks guys!! Super pumped! Barrie stop by anytime!
Hopefully going to dive into some engine work today.
Old 04-15-2012, 06:38 PM   #300
Chris916
Chris916's Avatar
So the motor is all back together. Found out i had (very) low compression in cylinder 3 because a valve seal was pooched. Replaced that and lapped a few valves and she's all good. Swaped the block for another one i picked up. Hopefully it's in a bit better shape. After finishing up the engine, having only the oil pan left to put on, I made a stupid mistake and knocked over the pan and managed to break a off corner. So I have another one on the way, and that's all i'm waiting for to finish up the engine.
This weekend started re-wiring the car. Hoping to have the wiring all done and engine back in the car by the end of next week.
Also got my wheels on friday and just had to test fit them!
Looks like i'll need a bigger spacer in the front. The rim is just touching the strut.
