Old 02-16-2011, 12:47 AM   #1
bersky
2001 330 ci weird shaking
i have a 2001 330ci with a weird shake in the front end when i bought the car i had 19's on it i was driving on the highway at around 100 and the steering wheel was violently shaking. i first thought breaks but had no pedal pulse. i changed to my winter tires which are 17's and the shake isnt as bad but it still there any thoughts? there is no grinding noise's or anything but my front left tire seems to wear on the inner part of the tread more
bersky is offline   Reply With Quote
Old 02-16-2011, 01:16 AM   #2
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Does it get worse while braking? Could be your front control arm bushings.
Old 02-16-2011, 01:51 AM   #3
Tierods, balljoints, or bushings...all can cause this.
Old 02-16-2011, 01:59 AM   #4
bersky
it only does it at certain speeds like 90-105 120-130 there is no clunking and no it doesn't seem to get worse while breaking it still does it but with no pulse in the pedal
Old 02-16-2011, 09:50 AM   #5
prince1
on to the next 1
prince1's Avatar
Send a message via MSN to prince1
try a completely diff set of rims. both your set might be bent or warped. try taking ur winters in for balancing.
LOL
Originally Posted by TNation View Post
Yo man, I got $6000 in my bank account, and I could buy any car i want
Ya man with $6000 in the bank, you're really balling arnt ya
prince1 is offline   Reply With Quote
Old 02-16-2011, 06:19 PM   #6
oakville46
+1 ... first time this happened to me my control arm bushings were done. Recently, it was the tie rod bushings.
oakville46 is offline   Reply With Quote
Old 02-16-2011, 06:46 PM   #7
Another BM
i got my summer tires and rims off my car...
They ride perfect if you want to put them on your car and go for a ride your welcome to
Another BM is offline   Reply With Quote
Old 02-16-2011, 10:16 PM   #8
B6T
+1 for getting your wheels balanced.
Summer: BMW 135i M-Sport
Winter: 2004 Audi A4 Ultrasport 2.7tt
Year round: 6 cylinders, two turbos, and 6 speeds.
B6T is offline   Reply With Quote
Old 02-16-2011, 11:37 PM   #9
bersky
im pretty sure it is mt front control arm bushings! thanks for all the replies guys
Old 02-17-2011, 12:24 AM   #10
Any good shop should be able to identify it in a few minutes, just need to check for play in the mentioned parts. Get it done ASAP as you will damage tires and other components with that vibration
Old 02-17-2011, 01:57 AM   #11
drivetolive
drivetolive's Avatar
I have the same issue (on two different sets of rims/tires, going to try a third set after winter).
Mine is apparent however even at lower speeds (can feel the pulsation in the steering wheel and car in general). It does get worse at highway speeds, especially in the floorboards, seats and the whole car in general. One thing I have noticed is that sometimes it isn’t as bad sometimes (for example, for some reason it is worse after the car has been sitting for a while).
Another thing I noticed with the steering wheel was after driving for about an hour, the steering wheel vibration almost completely went away (until the next day).
All of my suspension components check out (it’s a ’04 with ~83k) and are fine. I’m stumped as to what it could be, if you figure it out please post back.
drivetolive is online now   Reply With Quote
Old 04-02-2011, 02:50 PM   #12
sol_searchin
Do your rims have hub rings?
sol_searchin is offline   Reply With Quote
Old 04-02-2011, 03:18 PM   #13
BimmerGuys
BimmerGuys's Avatar
Tires, rims, then tierods, balljoints, or bushings.
Sell My Car Fast
BimmerGuys is offline   Reply With Quote
