Old 02-14-2011, 10:57 PM   #1
dble Trouble
TAKE IT TO THE TRACK
dble Trouble's Avatar
High NO in Etest and failed
I know it's pointing to a bad cat, but could it be something else? Or can I bandaid the problem by retarding the timing or something to just pass the test and then put the timing back?
any helpful hints or help would be greatly appreciated!
Or if it is the cat, anyone got a good cheap one around???? LOL.
Old 02-14-2011, 11:05 PM   #2
Unfortunately, you can't change the timing in these cars. It's in the chip.
Old 02-15-2011, 01:27 AM   #3
El Gato Liso
El Gato Liso's Avatar
take your ICV out and clean the inside good with rubbing alcohol and Q-tips.
put some 91 oct in + 2 bottles of injector cleaner.
run the car up and down the highway and go WOT blow shit out.
then go etest while hot hot hto.
R.I.P. E30
Old 02-15-2011, 02:16 AM   #4
I would recommend SeaFoam additive instead of injector cleaner. Use as directed, I passed with nearly no detectable emissions after nearly failing the years earlier.
Old 02-15-2011, 07:26 AM   #5
canuckder
canuckder's Avatar
SeamFoam ftw,
Also what el gato said, test hot.
even go on "training" while on the machine and let the car warm up abunch.
canuckder is offline   Reply With Quote
Old 02-15-2011, 04:51 PM   #6
Nick_V
Nick_V's Avatar
If you're failing due to NOx, it might actually be better to test it cold if you're close to passing. High NOx levels are related to high combustion temps, usually resulting from a lean condition (vacuum leaks, bad injector, etc).
Does the M20 use an EGR valve? I was chasing the same problem with an M42 last year but that motor does not have an EGR system and relies solely on the cat (and proper AFRs) to regulate NOx levels. If the M20 has one then you might look in that direction, as that's what it's there for, AFAIK.
Old 02-15-2011, 04:53 PM   #7
No EGR on the M20.
Old 02-15-2011, 05:54 PM   #8
methyl hydrate will dramatically reduce your NO
Old 02-15-2011, 06:38 PM   #9
sLvr325i
Could you post your e-test results as well as the age of your emmisions components? that'll really help identify a potential solution here. I dont know you or your set up... if you have some kind of A/M intake/air filter...etc.
Let's see what your margins are for CO and HC too... chemically altering your fuel aint a bad idea but its pointless to reduce your NOx and fail HC and CO
sLvr325i is offline   Reply With Quote
Old 02-15-2011, 06:56 PM   #10
hmm. I've never had a car fail with methyl hyrdrate mixed in with the gas,
and its passed all but one car that we tried it on (about 85% success rate)
Frankly, i'd be more worried about doing damage to the motor than failing.
Old 02-15-2011, 07:22 PM   #11
sLvr325i
Originally Posted by propr'one View Post
hmm. I've never had a car fail with methyl hyrdrate mixed in with the gas.
100% success rate?
and its passed all but one car that we tried it on.
99% success rate?
(about 85% success rate).
leveling off at a respectable 85% success rate?
If he used about 2L to an eigth of a tank and then filled up after to dilute then that minimizes the corrosive effects... still dont know his numbers though....that'll be a good indicator.
Old 02-15-2011, 09:12 PM   #12
Nick_V
Nick_V's Avatar
Methyl hydrate will NOT lower NOx. It burns hot and will help to lower HC/CO if you're running rich, but will send NOx through the roof, especially if you're already running lean or if you use too much.
Old 02-17-2011, 02:51 PM   #13
sLvr325i
It wont really send the NOx through the roof nick... there are still so many varibles into using this stuff and its outcomes.. if anything NOx may decrease slightly because the meth burns so much cleaner and it's less volitile than gasoline
Old 02-17-2011, 02:55 PM   #14
Just run Seafoam. My co and nox were nearing their limits, but a can of Seafoam and a hot cat gave me 0.02 CO (!) and 25 NOx.
It will be interesting to see how my turbo passes this year.
Old 02-19-2011, 11:35 PM   #15
talltorontoguy
Go Topless
talltorontoguy's Avatar
I'm wondering the same thing. I had my car classed as a "hot rod" last time with the M30 engine swap and so only have to meet minimal etest requirements...much higher thresholds than the standard for an 88 m20.
Join BMW Club of Canada! Click HERE
Best Engine, Bimmercruise '10 / 2nd - e30 Wild, Bimmercruise '10 / 1st - Best Cabrio, Trillium @ Tedfest '11 / 1st - e30 Wild, Bimmercruise '11 / 1st - e30 Wild, Bimmercruise '12 www.vertnation.com
talltorontoguy is offline   Reply With Quote
