Old 12-20-2011, 06:35 PM   #1
roblins
Roblin's Garage
New OEM 1967-2010 BMW Parts (List Inside)
Lots of new OEM (post in packages) BMW Parts. Worldwide shipping available.
3137000035 - Unknown
7119902007 - 1971-08 3-4-5-6-7-Series Hex Bolt w/Washer
7129946304 - 2007-10 3-Series Hex Nut
11141725994 - 1987-01 7-8-Series Shaft Seal
11151730507 - 1990-96 3-Series Hose
11151735150 - 1990-96 3-Series Hose
11211308467 - 1986-93 M3 Sprocket
11231263879 - 1977-84 5-6-7-Series Vibration Damper
11251713194 - 1981-96 3-5-Series Repair Kit Piston Rings
11421745392 - 1987-98 5-7-8-Series Supporting Dome (11 available)
11531247261 - 1995-99 3-Series Water Hose
11531741412 - 1989-95 850-Series Water Hose
11531742291 - 1992-95 5-7-Series Clamp
12121705675 - 1967-01 3-5-6-7-8-Series; 1602-2800; 3.0 Series Ignition Wire
12141740663 - EPROM Chip (Unknown application)
12147831762 - 1999-03 M5, Z8 RMFD Basic Control Unit
13711747995 - 1992-95 540/740-Series Rubber Boot
16121116966 - 1974-87 5-6-7-Series Gasket
17111723348 - 1991-99 3-Series Covering Left
17111737713 - 1994-03 5-7-Series Rubber Strip, Left
21521114101 - 1967-76 1602-2002 Pipe
22111141792 - 1994-95 740-Series Right Rubber Mounting w/Flange
22316753316 - 1989-99 3-Series Rubber Mounting
23121222771 - 1990-10 1-3-5-Series Repair Kit, Shaft Seal
23121282394 - 1968-10 1-3-5-6-7-Series; 2000-2002; 3.0 Series Shaft Seal
23311209342 - 1977-90 3-5-6-7-Series Selector Shaft
24511422115 - 1995-10 1-3-5-6-7-8-Series Support Noise Absorbing
31331090612 - 1994-10 3-5-6-7-X-Z-Series Upper Spring Pocket w/Axial Cage Bearing
31336752646 - 1998-06 X5 Support
32411137562 - 1987-95 750/850-Series Pressure Hose Assembly
33121468892 - 1969-99 3-5-6-7-Series Tapered Roller Bearing
33219067810 - 1982-91 3-Series Repair Kit, Bellows, Exterior
33411120038 - Unknown
35411152744 - 1977-93 3-5-6-Series Grommet
roblins is offline   Reply With Quote
Old 12-20-2011, 07:55 PM   #2
You will need to clear this for sale thread with an admin.
Old 12-20-2011, 08:01 PM   #3
roblins
Roblin's Garage
41328164112 - 1994-01 740/750-Series Pipe
41521960324 - 1990-98 3-Series Right Lower Rear Door Hinge (2 available)
41528135510 - 1990-98 3-Series Right Upper Rear Door Hinge (3 available)
51112265639 - 1990-99 3-Series Cover
51117009893 - 1998-06 X5 Cover Lateral Left
51117009894 - 1998-06 X5 Cover Lateral Right
51118124423 - 1989-97 840/850-Series Gasket Left (47 available)
51118233302 - 1994-01 740/750-Series Cover, Top
51148209932 - 1995-10 3-5-7-Series Grommet
51168150956 - 1994-01 740i Right Rear Door Sun Blind
51168169707 - 1994-01 740/750-Series Sun Blind Support
51168216705 - 1991-99 3-Series Cover, Glove Box Lower
51228204419 - 1995-03 5-Series Waist Rail Trim Strip, Interior, Left Rear
51321904509 - 1982-98 3-Series Base (2 available)
51321906497 - 1982-91 3-Series Cover
51321913440 - 1982-91 3-Series Stop Disk
51337008409 - 1998-06 X5 Clamp
51348266125 - 1997-05 3-Series Window Guide, Left Rear Door
51348266126 - 1997-05 3-Series Window Guide, Right Rear Door (2 available)
51348408315 - 1998-06 X5 Cover, Column C, Left Rear Door
51357020583 - 1998-06 X5 Left Rear Window Guide
51418397540 - 1995-02 Z-Series Cover, Front Right Loudspeaker
51472261407 - 1988-02 3-5-Z-Series Front Floor Parcel Net
51478174510 - 1994-01 740/750-Series Front Right Sill Strip Sandbeige
51478219192 - 1997-05 3-Series Right Rear Entrance Cover
51478227521 - 1997-05 3-Series Cover Molding, Sill, Front Inside
51717022394 - Unknown (2 available)
51718209581 - 1995-01 740/750-Series Heat Resist Plate, Carbon Canister Left
51718216117 - 1997-10 3-6-Series Cover Cup, Hook (3 available)
51911880835 - 146 alpineweiss paint
52107011773 - 1999-10 3-6-Series Cover, Belt Guide, Left
52108150011 - Unknown
52108150012 - Unknown
52108207205 - Unknown
52108207213 - Unknown
52108207214 - Unknown
52108217293 - 1994-03 5-7-Series Cover, Sandbeige
52108248211 - 1998-10 3-6-Series Covering, Seat Rail Left
52108248212 - 1998-10 3-6-Series Covering, Seat Rail Right (3 available)
52108260846 - 1998-10 3-6-Series Right Set of Covers
52208199791 - 1994-01 740/750-Series Armrest Upper Leather
52532308674 - 1997-03 K1200LT RR Side Molding
54121978719 - 1986-95 5-7-Series Drive Cable Left
54318413877 - 1995-02 Z3 Left Tension Rope (2 available)
61126909892 - 1994-06 3-5-7-Series Replacement Cable, Front Airbag & Control Unit (2 available)
61128386374 - 1995-02 Z3 Replacement Cable Tensioner Cable & Control Unit
61138359365 - 1991-96 525/530-Series Right Cable Gift
61128386918 - 1994-99 318ti Wiring Co-Driver's Side
61211389010 - 1988-99 3-5-Z-Series Battery Hold Down
61318368921 - 1997-05 3-Series Window Lifter Switch, Rear
61361393412 - 1995-03 5-Z-Series Minirelay, Make Contact, Yellow
61618403036 - 1998-06 X5 Wiper Blade
61628402374 - 1998-06 X5 Rear Window Wiper Arm
62131383311 - 1986-02 3-5-7-8-Z-Series Bulb, 12v
63136900532 - 1994-06 3-7-Series Additional Turn Indicator Lamp, Right, White (42 available)
63318350554 - 1986-99 3-5-7-8-Series Engine Compartment Light
64211391387 - 1990-96 525i Hose Front Engine Inlet & Water Valve
67616910471 - Unknown
67918366501 - 1992-06 3-Series Filister Head Screw (3 available)
72118119186 - 1990-02 3-Z-Series Covering Cap (4 available)
82111467015 - 1988-95 3-5-7-Series Alarm Transmitter 3-Button
82129401297 - 1992-97 740/840-Series Exhaust Pipe Tip, Black
82129410927 - 1997-05 3-Series Exhaust Pipe Tip, Black
84110009118 - Telephone Adapter Cable (Unknown Application)
84110018038 - Bluetooth Voice Imput Jumper Plug Adapter (Unknown Application)
84110025687 - Wiring Harness (Unknown Application)
84110025709 - Telematic Control Unit (Unknown Application)
84110027938 - Antenna Mount (Unknown Application) (5 available)
84318380338 - 1994-06 3-5-7-X-Z-Series Hands Free Telephone Microphone
84506907085 - 1997-06 3-Series Roof Antenna Base, Dualband (2 available)
84506907302 - 1995-03 5-Series Antenna Radiator
84506907304 - 1995-03 5-Series Rear Window Telephone Antenna Base
84506907306 - 1995-03 5-Series Connecting Box
Old 12-20-2011, 11:04 PM   #4
better check with Moderator or your posts may be deleted. :-)
Old 12-21-2011, 01:04 AM   #5
roblins
Roblin's Garage
I read the sticky guidelines at the top.
I'm not a business; just a private seller that sells auto parts on the side. I picked up 3 or 4 large boxes of OEM BMW parts at auction and thought this might be good place to advertise them. This is all that I have. I have no supply source nor expect to find anymore. I've never bought BMW parts before
I'm not spamming, cross-posting and keeping all the items into one thread.
I'm also not trying to cause trouble. I don't own a BMW so I really have nothing to contribute except this thread.
Old 12-21-2011, 02:07 AM   #6
If you buy and sell things, it makes you a business...unless you want to sell those boxes for what you got them for
Sorry if it sounds harsh, but everybody wants to make $$$ and not spend any, but fact is advertising costs a LOT.
If you just want to "help out this community", i'll be happy to take those parts and distribute them for free!
Old 12-21-2011, 02:16 AM   #7
richie_s999
Guess u missed the sentence that says you can post 5 items per month.
Old 12-21-2011, 02:28 AM   #8
roblins
Roblin's Garage
Sorry - you are correct. I did not read that as was in a sub-sticky. I did not mean to violate a "rule"
Feel free to have everything in this thread deleted.
