11-22-2011, 04:35 PM
Permanently Dirty
Car: E30 1990 325I
LOL!, Need some suggestions please...
hopefully you only laugh for a few minutes then maybe help me out with something constructive
went to go change my oil today in regular fashion
jacked up the car, put down a sheet of plywood, got drain pan start unwrenching drain plug, drainplug comes loose, spins forever.... DUH! I've just tightened it and stripped the threads
heres where you laugh.. now I need some help
Good news: plug isnt leaking doesnt come out when I pull it takes some effort to even spin
Bad news: gotta change the oil sometime
heres what I'm thinking to do...
force it out drain the oil, go buy a reamer and tap and make it fit a slightly bigger oil plug
since I dont have the time to just lift the engine and swap a new oil pan...
As I already have the oil, and its not leaking, if I throw some gasket maker on it (for security) and take it to a shop to do(school sucks), would you think it would cost me under $100 for them to retap and fit a new drain plug? /try and tell me I need a new oil pan
or is there just a better way?
11-22-2011, 04:46 PM
the misanthropist
Car: '05 4Runner, 87 325
EDIT: nevermind, I first thought you broke the plug... they're normally hollow so if you overtorque them, they break instead of stripping threads. Yeah try to get it out and tap for a bigger thread, or maybe helicoil it. Changing the pan is such a pain that you should try all else first.
11-22-2011, 04:50 PM
Car: e36 m3
Righty Tighty, Lefty Loosey!
11-22-2011, 04:58 PM
Car: 200* s54@
unless its the clutch fan
11-22-2011, 05:27 PM
Permanently Dirty
Car: E30 1990 325I
Thats a good point .. i'm gonna be honest I dont know wether ive broken it or stripped it... I guess I could have done a bit of both at this point
11-22-2011, 05:52 PM
Over 9 F**KING THOUSAND!!
Car: '91 325iS | '96 332i
Or vanos bolt
11-22-2011, 06:41 PM
Car: 90 325i
Tap a bigger hole, use a bigger plug.
11-22-2011, 09:25 PM
Car: E30 touring
Drill and tap bigger hole is a good idea, I bet you can find one at CDN Tire.
11-22-2011, 09:42 PM
Car: Gettin One Soon
You could temporarily put in a repair plug
Im pretty sure CT or partsource sells them.
1995 E36 318is
Engine Mods: 94 M50 motor, Lightweight Flywheel, SACH clutch, UUC shifter, Electric Fan, Header and Full Exhaust, Magnaflow muffler, CAI, Racing Dynamics Chip
Exterior Mods: M3 spoiler ( Not installed yet), Projector Headlights, M3 mirrors.
Suspension Mods: Front Strut bar, Eibach spings, Billstein Struts.
Interior Mods: M3 buckets, Reverse Glow gauges, Momo steering wheel, M3 Shift Knob, M3 Headliner
11-23-2011, 12:48 AM
#10
Car: 87 325is
if you tap it without taking the pan off the motor there's no way you will keep metal out of the pan. id be careful cause running chips through your motor would be a hell of a lot worse than lifting the motor to change the pan properly.
11-23-2011, 09:00 AM
#11
Car: 328i & 327i turbo
This is the first thing I thought of. I had to drill out and re-tap a bleeder screw on a brake calliper that snapped off. I thought I did a good job flushing it out... about a month later the calliper seized up
It's not that hard to remove the oil pan. Just unbolt the motor mounts and jack the motor up enough so it will clear the oil pump, if you still have the bracket that the AC mounts to that's a nice spot to jack it up. Also be cautious to unplug any electrical connectors that might get stretched as your jacking the motor. And if you have a strut brace make sure to remove that first. When I went to change my motor mounts this year I was like WTF! I can't jack the motor high enough to get the mounts off.... then I was like oh...strut brace
Just do it on a weekend because it will be an afternoon job if it's your first time. And make sure to get a new oil pan gasket.
11-23-2011, 12:41 PM
#12
Parts Hoarding Specialist
Car: '91 318i, '91 318is
I have a pan
in my trunk
right now.
1986 E30 325e (killed)
1986 E30 325es (died)
1988 E30 325i (rotted)
1992 E34 525i (sold)
1992 E30 318i (cabrio, Dad's)
1989 E30 325i (Mom's)
1991 E30 318is (Winter car)
11-23-2011, 12:54 PM
#13
Permanently Dirty
Car: E30 1990 325I
I think what I'm gonna do is goto steve (325isStephen) to get it swapped, he offerd me his pan already, thanks Scott
11-23-2011, 01:06 PM
#14
He's definitely experienced with swapping smashed M20 oil pans
11-23-2011, 04:27 PM
#15
No problem. I've been looking for an excuse to not ship it to a guy in the states. Less hassle for me, but no worries.
