Old 02-06-2011, 04:43 PM   #1
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
Send a message via MSN to AlpWhitE46
Light bulb housing got Owned!
I was replacing a bulb that burned out (had another thread about this)...
turns out i had 100 watt bulbs in there instead of 55 watt..
however nothing has happened for the 5 years they were in there..
I bought the nighthawk extra bright ones now, the 55watts, and just replaced the 100 watt one that burned out.. and i was going to do the other side when i had time.. (today)...
Don't make fun of me but i didn't know having two different bulbs would cause a problem...
you can see the top of the housing has burned, and i can't get the new light to sit in properly
difference between left (new light put in 1 week ago) and right, new light put in now, with the burn
quesiton is what can i do? is there a part that i can get for the inside, that housing?
AlpWhitE46 is offline   Reply With Quote
Old 02-06-2011, 04:51 PM   #2
buy a new headlight.
Probably best to upgrade to hids.
Old 02-06-2011, 04:58 PM   #3
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
Can't i just get that silve piece inside? like the cone...
Whole headlight assembly? thats so expensive..
or did you not understand me properly? the new headlight is already in (not in the 1st picture) but its 100% new and working fine... the bulb housing just does not fit properly in the silver piece
because its burned and I'm guessing light is also distorted in there because of that.
Old 02-07-2011, 01:48 PM   #4
1bmw1
I'm not too sure myself if they sell just that dome part of the headlight individually. You might have to check the parts guys for a used one, or it might be worth it for you to get yourself a used pair of headlights, and maybe a good chance to upgrade to xenons.
Old 02-07-2011, 02:17 PM   #5
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
this says it could?
hope tey have it
http://www.realoem.com/bmw/showparts...72&hg=63&fg=05
Old 02-07-2011, 02:18 PM   #6
Blades
Your opinion is to long
Blades's Avatar
thats hot
-=[ BL/\DES ]=-
Old 02-07-2011, 02:22 PM   #7
1bmw1
Hmm, looks like you're right. Call up Mike at Maranello to see if he can hook you up.
