Old 02-03-2011, 04:24 PM   #1
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
Send a message via MSN to AlpWhitE46
Oil light randomness?
I got my oil done maybe 3-4 weeks ago...
Note though, about 6-8 months ago i got my vanos fully done from dr vanos, but to this day i still dont know the guy doing it put everything correctly, as from time to time the car will start a bit odd..
anyways since that oil change... every now and then when i start the car, the oil lamp will turn on (yellow) and stay on for 15 seconds and off it will go...
wtf?
AlpWhitE46 is offline   Reply With Quote
Old 02-03-2011, 04:35 PM   #2
Ceeker
Don't worry bout it; do you have sufficient oil pressure? car performs normally? then I wouldn't give it much concern until your vanos craps out and then take it back to the doc.
maybe it's just the oil pressure switch. could be when he redid the vanos may have touched something by mistake..Keep in mind it is pretty cold out so the pressure takes a bit of time to build up.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 02-03-2011, 04:48 PM   #3
Faulty oil level sensor. Very common E46 problem. Mine has been doing this since I've owned it but I'm too lazy to change out the sensor. That, and it's ~$200 for that stupid part.
Old 02-03-2011, 04:51 PM   #4
Michel
Michel's Avatar
if it were oil pressure, the light would be red, not yellow. Its your oil level sensor as Anuk said... make sure your oil actually isn't low though.
Old 02-03-2011, 04:59 PM   #5
Seyar
Seyar's Avatar
I had the same problem and as they said its your oil level sensor, nothing to worry about.
INTERLAGOS E36
Seyar is online now   Reply With Quote
Old 02-03-2011, 05:06 PM   #6
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
ok cool thanks, oil can't be low i just got it changed
thanks guys
Old 02-03-2011, 06:41 PM   #7
doogee
doogee's Avatar
thanks guys
E36's don't even have oil level sensors
Unless you're talking about your e46?
Dakar M3 Track Build Thread
Old 02-03-2011, 07:01 PM   #8
AlpWhitE46
is a pimp
AlpWhitE46's Avatar
E46, the E36 has been stored away
Old 02-03-2011, 07:29 PM   #9
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Check the oil level first. Could actually be low. Don't assume that because you just had an oil change that it's topped up.
Old 02-04-2011, 07:15 PM   #10
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
Rear main seal ? hope not
Old 02-06-2011, 12:01 AM   #11
new member
I love when non E46 owners try to guess the problem, lol.
Yellow oil light stays on for 10-15 sec after start up = faulty oil sensor. New one costs around $150
Yellow light at shut off = you actually are low on oil, not significant, but low. It could also be a possibility that you havent warmed up your oil before shut off and it hasnt come back down fast enough.
Yellow light while driving = you're low on oil. If it comes up when driving, means you're burning/loosing oil.
Red oil light when engine is on = low or no oil pressure. Oil pressure sensor is SEPARATE from oil level sensor just so you know.
Old 02-06-2011, 02:43 AM   #12
Pierce330
Pierce330's Avatar
Mine just started doing it as well...right after my last oil change...not an issue...
Pierce330 is offline   Reply With Quote
Old 02-06-2011, 09:04 AM   #13
Ceeker
Hey, I'm just learning like everyone else.. thanks. :-)
Old 02-06-2011, 02:16 PM   #14
3SERB
3SERB's Avatar
Rocco replaced my oil sensor at the last oil change. Its a two minute job and I think it was around 100 or maybe even less. Pretty useful thing to have working properly in my opinion.
...VLAD...
3SERB is offline   Reply With Quote
Old 02-06-2011, 02:18 PM   #15
BmW1819
dbworld4k is 100%
ever e46 will need to change this sensor sometime in it's life lol
