Old 02-01-2011, 02:07 PM   #1
bersky
e46 330ci need help!
hey i have a 2001 330 ci when i bought the car the guy said he changed the oil i dont think he used a very good oil so i changed it myself. when i did i noticed some weird creamy stuff under the oil cap. this scares me due to the fact of a blown head gasket. but there was no antifreeze in the oil could it possibly be something els?
bersky is offline   Reply With Quote
Old 02-01-2011, 02:24 PM   #2
Build up due to moisture. Just drive the car hard every now and then and it should be fine. My father's 330 had similar gunk developing under the cap attributed to the short leisurely commute that wouldn't even fully warm up the temp.
Old 02-01-2011, 02:34 PM   #3
bersky
ahh that would make sence! i only drive 5-10 mins to work everyday thank god lol i was soooo freaked out
Old 02-01-2011, 03:14 PM   #4
Pierce330
Pierce330's Avatar
My 330 does the same thing, it is nothing to worry about...
+1
Pierce330 is offline   Reply With Quote
Old 02-01-2011, 04:13 PM   #5
BimmerGuys
BimmerGuys's Avatar
Nothing to worry about in some cases is water condensation. Common with Volvos and BMW.
BimmerGuys is offline   Reply With Quote
Old 02-01-2011, 05:03 PM   #6
Common 330 issue in particular. Run the proper oil (BMW LL-01...Mobil 1 0w40 is the easiest to find) and as Anuk said try to avoid short (< 10min) trips.
Old 02-01-2011, 06:55 PM   #7
slemmer
Driving in the fast lane
slemmer's Avatar
Yeah and give her a good run on the highway to blow out all that crap that accumulated from the short hauls.
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 02-01-2011, 08:50 PM   #8
mclovin
Happens o my 325 as well with bmw/GC oil
i work about 10 minutes away from home
mclovin is offline   Reply With Quote
Old 02-03-2011, 02:26 PM   #9
new member
Very common issue with E46s. Like everyone said its due to condensation build up from oil. CCV is supposed to do its job and separate the vapours but the car needs to be driven for a while before it starts working as the CCV is vacuum controlled.
If your CCV has not been replaced and you;re at over 120kms, change it. I did it last week with the new Cold Weather version so that I dont have to worry about it.
Also, correct oil is a must. For our canadian weather there is NOTHING better the Castrol 0W30 Euro Formula (the back of the bottle says Made In Germany) sells at crappy tire.
On the RIGHT in the picture below.
DSC_4764
Old 02-03-2011, 09:39 PM   #10
abrial
Excellence Auto Collision
abrial's Avatar
Send a message via MSN to abrial
so just a question about oil, what kind of oil do you guys use for yours e46? because I'm looking for something better than Rs200 that I'm using now. thanks
abrial is offline   Reply With Quote
Old 02-04-2011, 11:21 AM   #11
Pierce330
Pierce330's Avatar
I run 5 40 Lubrimolly
Old 02-04-2011, 11:28 AM   #12
abrial
abrial's Avatar
Where did you get it? And how much did you pay? Thanks
Old 02-04-2011, 11:31 AM   #13
Pierce330
Pierce330's Avatar
I'm pretty sure that all of the independent shops in your area Ie. RMP and Bimmersport use it...lubrimolly/total/elf...
Old 02-04-2011, 11:52 AM   #14
abrial
abrial's Avatar
Rmp has only rs200, but i dont really trust to that oil.
Old 02-04-2011, 01:21 PM   #15
Which is the incorrect oil. Check the BMW approval on it, it's either LL-98 (which doesn't meet the requirements for your car) or LL-04 (which is not supposed to be used in North America as per BMW's recommendation...fuel quality related).
Run LL-01 oil. BMW genuine 5W-30, Mobil 1 0W-40, Castrol 0W-30 (German), Motul 8100 5W-30, Motul 8100 5W-40, and a few more scarce ones.
We use LL-01 oil exclusively, for non-M cars.
