Old 01-31-2011, 09:36 PM   #1
dannyb
rear subframe 6mm allen stuck
Anyone know how to remove these? There are starting to strip... If all goes to hell can I drill these out and replace them with new ones?
dannyb is offline   Reply With Quote
Old 01-31-2011, 09:44 PM   #2
Heat + vicegrip. Yes you can replace them no problem.
Oh yea, careful with heat if you got a torch... gas tank
Old 01-31-2011, 10:08 PM   #3
e30_kid89
The Afro-stig
e30_kid89's Avatar
.....and afterwards do yourself a favor and replace those stupid allens with 13mm regular hex bolts. You'll thank yourself next time if/when you have to pull the subframe for whatever reason!
Old 02-01-2011, 05:19 PM   #4
DR.ZED
I put antiseize on the bolt and covered the head of it with grease and the back end. Wipe off anytime and fresh bolt.
My old ones, I did have to use vice grips.
Cam G.
85 325e M5
07 Honda Shadow Spirit 750
Old 02-01-2011, 06:09 PM   #5
One of mine snapped off before it even started to strip when I did the subframe last year, just drill it out and put a nut and bolt like e30_kid89 said
Old 02-01-2011, 07:02 PM   #6
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
Go buy a set of stainless bolts lock washers, and nuts. 4 sets of course. Why put something there that will rust?
Old 02-01-2011, 09:26 PM   #7
dannyb
So I stripped them, tried to drill them but my bits are really cheap, getting new bits tomorrow.
Old 02-02-2011, 10:24 AM   #8
sLvr325i
Cobalt bits are amazing. maybe another stupid question but you do know how to drill properly right? (without over heating and ruining new bits)
sLvr325i is offline   Reply With Quote
Old 02-02-2011, 11:02 AM   #9
E36is
'OldSchool..'
E36is's Avatar
^^ also make sure your drill is set for forward not reverse... it happens
Old 02-02-2011, 04:31 PM   #10
dannyb
cheap bits i got in a kit for 20$, i bought some cobalt bits today, ill give it a try later
Old 02-05-2011, 12:51 PM   #11
dannyb
cobalt bits are amazing, drilled them out in no time... Subframe is finally out, did anyone ever use the adjustment tabs you weld onto your subframe?
Old 02-05-2011, 04:24 PM   #12
sLvr325i
what did the bits end up costing? last kit i had i remember being 168 bucks
Old 02-05-2011, 05:25 PM   #13
dannyb
40$ but it only goes up to 1/4, theres 14bits i think
