01-31-2011, 12:41 AM
#1
Car: 318ti
need help. how to remove the trunk lock?
my trunk lock doesnt work. I would like to take it out, see what's wrong with it. But the problem is that I have to remove those two stuff first(show in the picture). I have no idea how to remove them, they are not screws something.
anyone has any idea? please.
thanks
01-31-2011, 12:49 AM
#2
Over 9 F**KING THOUSAND!!
Car: E46 M3
Something like this:
You can do it with a thin flat screwdriver and patience, although I wouldn't recommend it. Best is to use the above tool (available at crappy tire, princess auto, etc).
01-31-2011, 12:57 AM
#3
Car: OE///M
+1! They are just clips and should be "easy" to pull out...
01-31-2011, 01:10 AM
#4
Car: 318ti
thanks. and do you know what's the parts number of that stuff ?
01-31-2011, 12:16 PM
#5
Car: 325IS 87-325IC 92-IC
chances are you'll be able to re-use the clips. once those are off you'll be able to pull the panel loose. if the clip breaks just take it to bmw and most cases it will be in stock if not they'll order it. Don't worry, they won't ask you to leave your arm for deposit.
01-31-2011, 12:32 PM
#6
Car: e36 328is S/C'd
i cant open my trunk at all... i bought a lock for it, i just gotta find a way to get the trunk to open... anyone know how to open a jammed trunk?
e39 M5 (s62)- Muffler Delete, Timmay Tips,
e30 325ic - Hard Top, Matte Black
e36 328is - (m52)AA S/c'd, M50 Mani, 3.23 LSD, M3 Brakes, Zimmer rotors, hps pads, Racing Dynamic Strut Bar, Depos, m3 Bumper, Intake, Spal fan, poly RTABs, Eibach Swaybars, Koni yellow, Mishimoto Rad, Silicone hose, Alumi T-housing, Depo w/LED Angels, LED tails, 12' Alpine Type R, Suede head liner, LTW Low rise spoiler
PREVIOUS CARS
92' 325is (m52) - M3 conversion AA S/c'd
'97 Euro Estroil E36 M3 Vert (S50B32)
02-02-2011, 02:30 AM
#7
Car: 318ti
i removed the lock and found a spring is broken.
i use a Elastic Band instead of it temporarily.
any idea for get the spring?
02-02-2011, 02:39 AM
#8
Car: 318ti
try fold down the back seat, get inside the trunk, then use a flat screwdriver to open it
02-02-2011, 03:36 AM
#9
Car: OE///M
I have many locks available, you can either change the full thing or use it for parts!
02-02-2011, 11:21 AM
#10
Car: 318ti
how much for the lock, my friend.
02-03-2011, 07:33 PM
#11
Car: E46 M3
Check with Maranello BMW, sometimes items like this are reasonably priced from the dealer. If it's really expensive then at least you'll know how much you're saving by buying used.
02-04-2011, 12:07 AM
#12
Car: 318ti
you mean the lock or the spring?
02-04-2011, 12:15 PM
#13
Car: E46 M3
Either. If it was my car I'd be buying a complete assembly, if reasonably priced.
02-19-2011, 01:11 AM
#14
Car: 318ti
i fixed it. saved money.
02-19-2011, 03:22 AM
#15
Spacers guy
Car: Audi A4
haha nice, cheap and proper fix
Thread Tools |
Display Modes |
