Old 04-15-2003, 02:34 PM   #16
Autotechnica
Little Chino
The M logos will come off easily on the brake and clutch pedals. I've had this problem before. I just stuck it on with some really strong epoxy glue, clamped it, then left it overnight to dry. Worked out great.
Your right the accel pedal is difficult to do. However, to make it easier there is a "C" clip that holds the accel pedal in place. You can remove the "C" clip and simply take out the entire pedal to make for easy install.
Brake pedal is metal, clutch pedal is plastic and accel pedal is plastic. It wasn't difficult to drill the holes, any drill bit will do.
Bryan
Old 04-15-2003, 02:51 PM   #17
punnzzells
punnzzells's Avatar
Send a message via MSN to punnzzells Send a message via Yahoo to punnzzells
The accelerator pedal is not supposed to go in flush to the floor... you have to raise the pedal.. that is the entire point... the "heel and toe".. you raise the accelerator pedal to allow for a higher pedal so you can "heel and toe" better...
i raised my pedal as high as I could... i left the m stickers off... maybe I will put them on... anyone have pics of theirs?
Mike.
punnzzells is offline   Reply With Quote
Old 04-15-2003, 04:04 PM   #18
Autotechnica
Little Chino
Mike.
That sounds like on OK idea. But I think you would have problems when braking. You might accidently hit the throttle. And that would put a strain on your ankles having the pedal so high. The whole point of heel and toe is to give a little bit of gas, and the stock pedals do that just fine.
Bry
Old 04-16-2003, 03:22 AM   #19
moregothanshow
All Show No Go!
moregothanshow's Avatar
hmmmm...i used to heel toe just fine until i changed my brake pads...now my brake pedal seems so much higher than my gas. oh well...i'll get used to it.....eventually.
Old 04-16-2003, 02:27 PM   #20
punnzzells
punnzzells's Avatar
Ya ture Bry,
but that 's what seperates the men from the boys...
lol
Mike.
