Old 01-23-2011, 08:51 AM   #1
parm
Scarboro Mazda S&L
parm's Avatar
Battery Tender advice
I’ve been trying to figure out the best way to store my battery this winter. My battery tender toasted my battery last night. I picked up a new battery and now not sure what to do put the tender on 2 to 3 days a month and leave it off the rest of the month or any other suggestions. I know I will get good advice on Max!
Parm
Old 01-23-2011, 06:28 PM   #2
parm
Scarboro Mazda S&L
parm's Avatar
This what I figured,
If using a trickle charger make sure you turn it off after a 2 or 3 days. Let car sit for 4 week then repeat, or get the trickle charger with maintain mode, it will turn on and off automatically, I toasted a battery by forgetting to do this and all the water dried/evaporated out of the battery from constant charging.
Old 01-23-2011, 06:48 PM   #3
Steve30
Techno Viking
Steve30's Avatar
I use a schumacher charger that I picked up from wal-mart for about 40 bucks. It's great, I left it on all last winter and doing the same this winter. You need to make sure that you use a tender instead of a trickle charger which constantly feeds a charge. That's what most likely killed your battery. The type of charger I use has a chip in it which constantly monitors the battery voltage and shuts itself off.
E36 ///M3 S54
???whp E30 coming soon.
Steve30 is online now   Reply With Quote
Old 01-23-2011, 07:35 PM   #4
Oyster
Send a message via MSN to Oyster
why not just disconnect the battery and trickle charge it before you need to use the car?
Oyster is offline   Reply With Quote
Old 01-23-2011, 08:00 PM   #5
Steve30
Techno Viking
Steve30's Avatar
My buddy disconnected his battery for a winter and the alarm went all wacky so its probably best to just leave it in the car.
E36 ///M3 S54
Old 01-23-2011, 08:01 PM   #6
damameke
schumacher is a good battery tender, as is Deltran..check out the Deltran battery, I use the Deltran and when the battery is charging the RED light will blink and when it is fully charged green light stays constant and it just maintain the charge...
Check with mike from Maranello, he is selling Deltran battery tender under BMW name
damameke is online now   Reply With Quote
Old 01-23-2011, 08:02 PM   #7
damameke
you also dont have to do the radio code using a tender...
Old 01-23-2011, 08:13 PM   #8
Steve30
Techno Viking
Steve30's Avatar
[quote=damameke;1476900]you also dont have to do the radio code using a tender...[/QUOTE
yeah, it also resets the adaptation on the dme so your car will have to "relearn"
E36 ///M3 S54
Old 01-24-2011, 10:11 AM   #9
parm
Scarboro Mazda S&L
parm's Avatar
I have the same Tender, you think I could leave it running outside in the cold?
Old 01-24-2011, 03:36 PM   #10
Steve30
Techno Viking
Steve30's Avatar
You mean on your driveway or something? The only thing I would worry about would be snow/rain shorting the charger. Right now mine is in the garage where its about 5-10 degrees warmer than the outside temp and its working fine.
E36 ///M3 S54
Old 01-24-2011, 09:20 PM   #11
MLue1
MLue1's Avatar
The CTEK MULTI US 3300 is THE BEST and it is available at Canadian Tire. It is the same unit as the "Porsche Charge-O-Mat II Battery Charger" that goes for around $120USD but w/o the cig lighter socket adapter. I picked mine up on sale at CT for $53.99, down from the regular price of $89.99.
CTEK MULTI US 3300
This is a smart multi-stage charger with some nifty features that will handle 12V motorcycle and car batteries. It is a charger-maintainer...connect it...forget it.
Features (user selectable):
- 0.8 or 3.3 amp charging rate.
- 14.4V or 14.7V cutoff, the latter is used for special batteries such as the Optimate and also for charging in colder temperatures.
- good for FLA (traditional wet) or MF batteries (AGM, GEL, Lead-Calcium).
- connector lock and are watertight.
Mark
'99 E39 540iT
Old 01-28-2011, 07:25 PM   #12
parm
Scarboro Mazda S&L
parm's Avatar
Its shelterd, does your have a small fan that always running?
Old 01-28-2011, 07:31 PM   #13
Steve30
Techno Viking
Steve30's Avatar
Yeah it does. If it's sheltered I don't really see a problem. The manual does say to use it in a well ventilated area.
E36 ///M3 S54
Old 01-29-2011, 03:01 PM   #14
Romaz
Is now married :D
Romaz's Avatar
I bought a CTEK 7002 from this place:
http://cgi.ebay.com/ebaymotors/CTEK-...#ht_3747wt_939
I ended up getting if for $120 shipped. Its a excellent unit!
Romaz is offline   Reply With Quote
Old 01-29-2011, 05:27 PM   #15
parm
Scarboro Mazda S&L
parm's Avatar
Roman, How ya Doing ?
