Go Back   maXbimmer Forums > Classifieds > For Sale > Drivetrain, Engines & Transmissions
Old 04-10-2003, 09:36 PM   #1
jeremy
Red face 98' m3 engine
my buddy (bmw mechanic) has a 1998 m3 engine for sale....comes with the ecu,wiring harness, manifolds, the ignition module, and all the regular bolt ons.....very low km's (i dont the exact number, i will find out though).....he is located in toronto.....the first $7,000.00 canadian takes it...pm me if your interested...
jeremy
Old 04-10-2003, 09:38 PM   #2
windsor318is
Nitrous Junkie!
windsor318is's Avatar
thats the 3.2 which means its alot more work to install ($$$$$)than the 3.0 like yours correct?
Old 04-10-2003, 09:41 PM   #3
jeremy
because of the obdII, but he knows how to bi-pass it...(with the use of the ignition module, i think)...i can ask him later when i see him
Old 04-10-2003, 10:02 PM   #4
sloveniaboy
sloveniaboy's Avatar
hmmmmmmmmm.....
interesting
Old 04-10-2003, 11:45 PM   #5
KennyTheGreat
KennyTheGreat's Avatar
Send a message via ICQ to KennyTheGreat
someone told me u could convert ODB2 to ODB1 again for a couple bills
is this true?
KennyTheGreat is offline   Reply With Quote
Old 04-11-2003, 04:36 AM   #6
r2edline
Send a message via ICQ to r2edline
oh ya, its true, there are certain parts you can change, dont know exactly what they are, but I know its possible. I've also seen OBDI conversion kits around too. Go to dtmpower and search for OBDI conversion or somethin
///red|ine
r2edline is offline   Reply With Quote
Old 04-11-2003, 04:37 AM   #7
ZiMMie
jeremy am very intrest but 7000 is too deep if he can wait till the end of this summer i will take i know by then i should have 7gs more..
#E36-S54 #CSLWannabe
Old 04-11-2003, 04:45 AM   #8
ZiMMie
i wish u can save this one for me...
Old 04-11-2003, 05:56 AM   #9
bmer332i
is this true?
Although I would debate the "couple bills" part of the statement,
it is true that you can convert the OBD2 setup to OBD1 spec by changing sevaral key components (mainly engine/fuel management). This is the setup I've been running on my car for a year and a half with no problems whatsoever.
Basically to do the conversion you will need the following:
1) OBD1 wiring harness and ECU (preferably from a 95 M3). You can use a 325 harness and ECU (93-95 w/vanos) but you will have to get software that's made for a 95 M3.
The ECU will have to be the "413" unit which is common to both later production 95 M3's and 325's (of course w/different software). You can also use the "506" ECU which was mainly used in the earlier production 95 M3's.
2) You will need the OBD1 intake runners from a 325 or 95 M3.
3) Also required is the fuel rail out of a OBD1 325 or 95 M3. You can use the 21 lb/hr injectors from the 3.2 engine on the donor rail .. however you will obviously need the software to take advantage of this. You can also opt to stick with the 17.5 lb/hr injectors that come standard on 95 M3's.
4) OBD1 HFM out of a 325 or 95 M3. These parts are common to both cars and share the same part number. A common upgrade (which I have done) is to use the Euro-HFM. This unit is 3.5" in diameter as opposed to 3" for standard. Mated to the correct software and injectors substantial gains can be seen on the dyno.
Turner, Jim Conforti/Eurosport, Active Autowerke all have these kits.
5) A tap or two (can't remember) will need to be drilled into the 3.2's head. This is to facilitate an extra sensor/s from the OBD1 electonics.
Dave at Motronix did the work in a weekend !! I got to help somewhat and learnt a lot by watching him and getting my hands a little dirty.
E36OBD1///M332i
bmer332i is offline   Reply With Quote
Old 04-11-2003, 12:24 PM   #10
punnzzells
punnzzells's Avatar
Send a message via MSN to punnzzells Send a message via Yahoo to punnzzells
Jeremy,
7g's is a little steep....but anything over $10 is too expensive...
but seriously, if anyone needs custom made pistons for that motor.... mmmmm.... lighter and stronger..... let me know... I can get em at a REALLY good price!
Mike.
punnzzells is offline   Reply With Quote
Old 04-11-2003, 12:26 PM   #11
jeremy
Originally posted by punnzzells
Jeremy,
but seriously, if
7 g's is a WICKED price....i paid $6,000 for my 95 m3 engine plus shipping from texas
Old 04-11-2003, 05:53 PM   #12
r2edline
just curious jermey, how much did you pay for shipping on your engine?
///red|ine
Old 04-11-2003, 07:05 PM   #13
jeremy
from texas to toronto around 350.00 (i think)
Old 04-11-2003, 07:09 PM   #14
Euro_E30
Euro_E30's Avatar
can he install it too ready to go ...how u think....
Euro_E30 is offline   Reply With Quote
Old 04-11-2003, 07:09 PM   #15
Euro_E30
Euro_E30's Avatar
how much u think...
