Old 08-19-2011, 01:10 PM   #16
DIY
Permanently Dirty
DIY's Avatar
Awesome! That's sooo tempting!
By SG dyno I meant SG motorsports dyno
Old 08-19-2011, 03:26 PM   #17
NOTORIOUS VR
NOTORIOUS VR's Avatar
no.. it's the dyno @ Magnus Motorsports in Vaughan... says so right on the dyno sheet
Old 08-19-2011, 03:44 PM   #18
JINT
JINT's Avatar
is this that green E30 VERT from scarlett and eglinton with BT that pulls me every time?
Old 08-19-2011, 03:50 PM   #19
e30_kid89
The Afro-stig
e30_kid89's Avatar
thats really good power for an m20 @ only 9psi!
I wanna play too! (soon)
Old 08-19-2011, 04:06 PM   #20
NOTORIOUS VR
^^^dooo ittt.... what are you doing to your car anyway lol
that would be the one
Old 08-24-2011, 01:21 AM   #21
NOTORIOUS VR
update...
Old 08-24-2011, 02:16 AM   #22
DIY
Permanently Dirty
DIY's Avatar
All I can do I'd stare in awe at how awesome all that work you guys did is. Just awesome!
Old 08-24-2011, 02:20 AM   #23
DIY
Permanently Dirty
DIY's Avatar
Although I am curious, does the boost graph make that curve, based on the size of the turbo, and/or because your not running electronic boost control?
Old 08-24-2011, 08:48 AM   #24
NOTORIOUS VR
The curve is because of electronic boost control (through the VEMS).
Basically I ramped the boost towards redline to flatten the TQ curve... but the controller is maxed out now... it will not give any more boost then what you see there (approx 23psi, the dyno reads around 1.5 psi more then in actual)
Old 08-24-2011, 09:52 AM   #25
Should post this in the thread on e30tech if you haven't already, that talks about bumping boost past the torque peak for a flat torque curve. This is pudding!!
Old 08-24-2011, 10:29 AM   #26
DIY
Permanently Dirty
DIY's Avatar
Thats cool! I don't know much bout tuning, its sweet you can do that! I always thought about using the controller for reduced lag
Old 08-26-2011, 11:50 PM   #27
bitchfree
i am the king ding-a-ling
bitchfree is offline   Reply With Quote
Old 09-09-2011, 12:23 PM   #28
NOTORIOUS VR
well the motor was short lived... we suspect an injector failure or injector drive failure of some sort... #6 piston.. the rest are still in perfect shape. Boost will be turned down to WG pressure for now until we find out exactly what caused this.
Should have it back together by the weekend. Yesterday the cam, rockers, etc were transferred to a new head and I spent 2.5 hours cleaning the aluminum off the cyl walls with Muriatic Acid... what a PITA.. but it all came off and we gave it a quick hone and it's ready for the replacement piston.
Old 09-09-2011, 12:29 PM   #29
As in it was running too lean on that cylinder and it melted the piston? That's what it looks like in the second picture.
Old 09-09-2011, 12:34 PM   #30
NOTORIOUS VR
correct, that is was we suspect... since #6 had a total melt down, but there rest are completely fine.
